Results 1 to 3 of 3
Thread: tune up suggestions
    Dec 2003
    32
    tune up suggestions
    anyone got a link (i remember reading one in the past) about what i should get done in a tune up. i have a 93 deville and want to get the thing running like when i first got it. a lot of people here suggest to change o2 sensors, which ill do along with the plugs/wires/air filter/oil change. anything else i should have done that you can suggest? thanks.
    AElayyat's Avatar
    AElayyat is offline Cadillac Owners Connoisseur
    Automobile(s): 85 Fleetwood Brougham, 90 Brougham 5.7, 05 Deville DTS
    Feb 2004
    So. Cali
    35
    1,135
    Re: tune up suggestions
    Clean out your fuel injectors, egr valve, make sure it is aligned correctly and you should get that good performance and gas milage.
    69
    82,278
    Why would you change the O2 sensors? If they go bad they will set a DTC. If they ain't broke, don't fix 'em.
  • You may not post replies
