99 deville RFA U1000 help
Results 1 to 2 of 2
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 99 deville RFA U1000 help in Past Cadillac Vehicle Discussion; I have a 1999 Cadillac Deville (220,000 kms). Recently my engine light came on and only current code is the ...
    J_Diggz09 is offline Cadillac Owners Member
    Automobile(s): 99 Cadillac Deville
    Apr 2009
    27
    14
    I have a 1999 Cadillac Deville (220,000 kms). Recently my engine light came on and only current code is the RFA U1000, which has something to do with the door locks? or remote. Could someone please tell me what could be causing it and how to fix? Thank you in advance
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,587
    Re: 99 deville RFA U1000 help
    Pull your codes again and post them all - Current or History. If the fault which set the MIL or SES light is there, it will show as C if it happens again within 3 start-run cycles and will stay as History for 40 successful cycles when it then self-clears.
    Sometimes the SES light needs to be manually cleared using your built-in diagnostics. The light is usually set by P code(s).
