The whats wrong with your 97-99 Deville thread
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, The whats wrong with your 97-99 Deville thread in Past Cadillac Vehicle Discussion; here is my list... first the minor stuff small chip in the windshield (thanks a lot ups driver) left headlight ...
    mrlacy is offline Cadillac Owners Fanatic
    Automobile(s): 99 Deville, 06 DTS Performance
    May 2006
    Dallas TX
    30
    140
    here is my list...
    left headlight is foggy
    black trim on the very bottom of car cracked near the rear passenger
    glove box wont open
    dash is peeling up on the pasanger side
    rear vents for the ac are broken
    now the mechanical
    exhaust pipes appear to be too low
    maybe something wrong with the cat??? (rattle when cold start WOT)
    excessive rattle in undercarrage when hitting bumps (have no idea what this could be)
    thats it...i say not too bad after replacing the following in 6 months:
    headgaskets
    plugs/wires
    fuel filter
    wiper blades
    rear lower bumper assembly
    tires
    vaulve cover
    water pump
    battery
    motor mount
    what is wrong with yours????
    97Purlwhyte's Avatar
    97Purlwhyte is offline Cadillac Owners Member
    Automobile(s): 97 Deville N*, 2005 CTS V6
    Feb 2009
    Miami, FL
    97
    Re: The whats wrong with your 97-99 Deville thread
    I drove for 2 months on a bad starter.. had it replaced twice b4 it worked right. The day the second starter got put in.. the wipers went out.
    (Of course it rained like 25 out of 30 days the next month)
    Right now I need...
    To find the misfire causing the p0300 code.
    a fuel filter, or fpr, or fuel pump.. going uphill, or stomping the pedal causes hesitation. If I ease down the pedal it'll accellerate just fine
    A wiper motor, or relay, or fuse box work. The radio works fine so Im guessing wiper motor
    Shocks, tires, brakes all the way around with an alignment. My CD skips at the slightest bump and the overall ride quality is way down.
    My trunk leaks in the spare wheel well, rusted my jack closed. So I need a jack.
    I need a heater core, and there's a leak somewhere on the high side of my AC. So I have little heat, no air at all. And a message for compressor being off due to low refrigerant level.
    Every 4 or 5 weeks I get coolant and oil level messages.. I just top em off and keep driving.
    My interior is immaculate.. no rips, burns, tears or stains inside. All my lights, dash, glove box, trunk and doors work fine. 147k miles.. bought it at 83k and it hauled ass..
    It still looks good, but two runs to Florida and back and forth to work have slowed her down a bit. I wish I could park it and gather all the parts i need to fix it at once.
    All this and a good wax and buff and she'll be a looker again..
    Playdrv4me's Avatar
    Playdrv4me is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 STS / 2005 MB G500 / 2003 STS / 2006 XLR-V
    Nov 2003
    TPA / STL / ICT / SAT
    11,694
    Quote Originally Posted by 97Purlwhyte View Post
    Every 4 or 5 weeks I get coolant and oil level messages.. I just top em off and keep driving..
    The oil one is no big deal, but the coolant one in the absence of a leak is something to keep an eye on.
    97DevilleBeige's Avatar
    97DevilleBeige is offline Cadillac Owners Fanatic
    Jul 2005
    Levittown
    33
    169
    Side view mirror is cracked
    Antenna doesn't work
    Rear shocks leak air, just had new compressor put in and it's working overtime, Arnott shocks ordered. $300
    Traction Control/ABS light goes on, need to replace speed sensor and hub thingy.
    Headlights very foggy
    What I can remember I've had done besides maintenance (brakes, fuel filters, etc)
    Headgaskets changed, $4k
    new short block engine additional $2k
    radiator, $200/300 not sure
    a/c compressor $1200
    brake line $200
    Auto level ride compressor $900
    Fuel gauge sensor $0 (warranty)
    Fuel Rail Line $0 (recall)
    2 Windshields $0 (insurance)
    Turn Signal Control Module (Don't remember how much)
    I'm sure there's others, just don't remember what else.
  7. Remove Advertisements
