Function question
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Function question in Past Cadillac Vehicle Discussion; I am new to Caddy's and I am still discovering new items of interest. There is one that I can ...
    Bowler807 is offline Cadillac Owners Member
    Automobile(s): 2003 DHS, 97 BMW Vert, 08 GMC Sierra Crew Cab
    May 2009
    Butler, PA
    87
    Function question
    I am new to Caddy's and I am still discovering new items of interest. There is one that I can not find an explanation for however. On both rear doors of my 03 DHS there is a 4 position rocker switch similar to the outside mirror control. I can not find anything in the owners manual that describes what these switches control. I have also sat in the rear seat and worked the switch and I still can't determine what they are for.
    What are they for????
    TIA
    dirt_cheap_fleetwood's Avatar
    dirt_cheap_fleetwood is offline Cadillac Owners Master
    Automobile(s): 1990 350 Brougham (The cruiser), 1988 Mark VII LSC (The DD)
    Aug 2007
    Woodridge, Illinois
    27
    5,545
    Re: Function question
    It is for the adjustable rear seat. The seats move forward and backward in the rear. If I remember right it also controls the rear massage, but Ranger will have to confirm that. If they do nothing than someone probably disconnected it while doing a rear window regulator and never hooked it back up.
    May 2009
    Butler, PA
    87
    I can see maybe 1 window regulator replaced, but not both rear regulators at 46500 miles. Neither of the controls do anything that I can determine.
    I ran the RPO codes and I find nothing for the back seats. If the controls are for both power and massage shouldn't it be listed on the build sheet?
    68
    81,926
    It's for the lumbar adjustment. If you press the top button twice it will give you a back massage. Fronts are the same.
    May 2009
    Butler, PA
    87
    Wow. Thanks. I wonder what other goodies this car has.
    68
    81,926
    The owners manual will tell you. It has several.
  9. Remove Advertisements
