Ride Quality, banging hard over bumps
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Ride Quality, banging hard over bumps in Past Cadillac Vehicle Discussion; Hey Guys, Thanks for the help on my other thread...... My 02 DHS has 64k.....It is not riding over the ...
    britcarman is offline Cadillac Owners Member
    Automobile(s): Cadillac 2002 DHS,03 F150,90 Broughm D'E. RWD,1973 TR6
    Sep 2008
    Boston, MA
    61
    35
    Hey Guys,
    My 02 DHS has 64k.....It is not riding over the bumps, potholes like it should.
    Its okay on fairly smooth surfaces...Its feels like the suspension is bottoming out over bumps. I don't see any signs of leaks at any of the corners. I do think the ride hight seems like its lower than it used to be. I will replace the struts and rear shocks...is the anything to check first with the other parts of the suspension, like electronics or air controls?
    It really doesn't feel like a worn out suspension....it seems like something not doing it job. It reealy bangs hard over the same bump I drive over with my F-150.......it did come up with "check suspension system" but it did not stay on.....When I say it bangs hard it really bangs, sounds like the wheel coming thru the fender!!!!!
    Thanks
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,619
    Re: Ride Quality, banging hard over bumps
    Either both struts and both shocks are shot (hard to believe at 64k) or your suspension control system is dead.
    Any codes set ?? See the sticky "how to pull codes" and look at the OBD-II link.
    69
    82,188
    Don't overlook control arm, sway bar bushings and sway bar end link bushings.
