The Back Story
In
September 2008 I purchased my
99 Deville with 98k miles on it. The terms of the used car loan were that I would need to purchase an
extended, 3rd party warranty. I had no issues aside from a faulty fuel gauge up until
February or March of this year when the
upper radiator hose had split. The hose was replaced with in the next day and there
wasn't any further problems until Easter weekend...
I was heading out on a 230 mile trip to visit family...I had traveled around 30 miles when I noticed the coolant temperature was abnormally high and rising.. It had risen into the 250s before I pulled over and turned off the engine. I turned the car back on and idled the engine and the temperature quickly came back down and I started off again. Not long after I would have to pull over yet again... I made the trip slowly and carefully and 3-1 gallon bottles of coolant later I made it to my destination.
After the weekend had passed, I took the car to a
local mom and pop shop and they
replaced the radiator under the extended warranty. Less than 30 miles later on the drive home, the temperature started to rise again... I made it back home with minimal problems by cranking the heat up and keeping my speed at an average of 50MPH... By doing this I maintained around 206 degrees on the trip home.
This time around I took the car to an actual
Cadillac dealer who told me the
thermostat was shot...they replaced it under warranty and all seemed well, at least for a few days.
Problem Found
A week later I dropped off the car to the
Caddy dealer and noon time they left a message saying the
time serts needed to be replaced and that the
head gasket is leaking and causing my rising temperatures.
To my dismay,
in order for the warranty to cover the engine repair they require a tear down of the engine (
at my expense, unless the repair is determined to be covered) to
verify the cause of the
gasket problem was not caused by the overheating problem. I don't have $900 to dish out for the tear down, let alone
gamble on a repair that may not even be covered by the extended warranty.
This problem has put me between a rock and a hard place... The Caddy is my only source of transportation, work is a 36 mile drive one way, and I'm stuck with a 40 month loan on this vehicle of which I'm only a quarter of the way through with paying. I've
done everything in my power to maintain the vehicle..but now I have to worry about the future of it and the loan.
A Loop Hole?
Almost every mechanic I've talked to thus far, from the mom and pop shop to the dealer warned me about this particular model of Caddy.. I've searched through forums and message boards trying to find some kind of answer or to see if there was a recall or any technical service bulletins.
In the last few days, my searching has finally paid off, or so I hope. I found 3 technical service bulletins listed on the Office of Defects Investigation's website.
The NHTSA item number(s) are as follows:
There is also a
service bulletin number listed which is "
99086"
Summary I'm 1/4 the way through a 40 month loan with a 10 year old vehicle (I have a two year/24 month extended warranty) that has a known problem with loose head bolts. How should I proceed? Who should I contact? What's the chance of my car being fixed? What are my rights as a consumer?
