98 Deville 135K Oil Pressure Low - Stop Engine
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 98 Deville 135K Oil Pressure Low - Stop Engine in Past Cadillac Vehicle Discussion; I have got this message three times in the last month. It always occurs within a few minute of starting. ...
    mrpib is offline Cadillac Owners Member
    Automobile(s): 1998 Deville
    Dec 2008
    37
    14
    I have got this message three times in the last month. It always occurs within a few minute of starting. I stop the engine, restart and all is well for days.
    I changed the oil and used 5W-30. Could that be the problem?
    The car is making no strange noises and it appears to me to be very much like an oil sending unit. Where is that located and how much more complicated would it be for me to change this on this year model myself than a regular oil change.
    Please advise.
    Sep 2003
    Metro ATL
    4,854
    Re: 98 Deville 135K Oil Pressure Low - Stop Engine
    Quote Originally Posted by mrpib View Post
    ....I changed the oil and used 5W-30. Could that be the problem?
    Possibly. You can do a simple test by changing to the recommended 10W-30 oil.
    The oil pressure sensor switch is threaded into the oil filter adapter plate. A little more time/effort involved than an oil change.
    Use only OEM GM parts for this switch (aftermarket pieces are not calibrated properly).
    68
    82,076
    5W30? Not in a '98.
