99 DeVille Towing Capability
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 99 DeVille Towing Capability in Past Cadillac Vehicle Discussion; Well guys the headgasket job is finished and right now I'm just doing small nit-pick things around the car like ...
    [NortHStaR]'s Avatar
    [NortHStaR] is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Cadillac DeVille
    Aug 2008
    Phoenix, AZ
    25
    279
    Well guys the headgasket job is finished and right now I'm just doing small nit-pick things around the car like touching up the paint and such.
    I am begining a new project now, I'm building a teardrop camper, which I know is about the lightest camper I can go with, but my question is what weight do I need to stay under to not have problems towing it long distances with my 1999 Cadillac DeVille?
    Any help and comments are welcomed
    Thanks in advanced for your help on this problem and thanks for your help on so many other problems I have had in the past
    dirt_cheap_fleetwood's Avatar
    dirt_cheap_fleetwood is offline Cadillac Owners Master
    Automobile(s): 1990 350 Brougham (The cruiser), 1988 Mark VII LSC (The DD)
    Aug 2007
    Woodridge, Illinois
    27
    5,545
    Re: 99 DeVille Towing Capability
    I would say nothing over 1000 lbs. but I would not tow anything with this car. You have to run wires for lights which causes nothing but electrical headaches. Also it is FWD so it will not handle much worse than if you were towing the same trailer with a RWD car. It also puts A LOT of extra strain on the transmission which was designed only to pull the weight of the car and these transmissions don't even fare well under just that amount of weight.
    Rodya234's Avatar
    Rodya234 is offline Cadillac Owners Connoisseur
    Automobile(s): 1998 Seville STS / 2013 Chevrolet Impala
    May 2008
    Chicago, IL
    24
    1,889
    My dad's '93 has a tow bar on it, we've used it to haul a couple of heavy TV's and it does it with no problems at all. Of course the load was no more then 600lbs max. The tow bar for a '93 is a Class 2 hitch , which means its rated for from 2001 to 3500lbs; max tongue weight is 350lbs. But it all really depends on how much load you want to put on your car.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,827
    Read the owners manual.
  7. Remove Advertisements
