Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: Finally started my TCC solenoid replacement today
Old 03-02-09, 05:39 PM
turbojimmy's Avatar
BAD EMAIL ADDRESS
Cadillac(s): 2001 DTS
View turbojimmy's Photo Album
Casino Cash: $2150
So I finally started my TCC solenoid replacement today. In between shoveling snow, I didn't get a lot done. But I did enough that I can't go back now.
I can't get the RH axle hub nut off. The real irony is that I put it on. You see, I paid a guy $1,200 last summer to replace my wheel hub assemblies and tie rod ends. When he told me both hubs were bad, I told him that I had just replaced it. He said "I don't know what to tell you, it's bad". So today, when digging into this transmission job, it became obvious that he did replace the LH hub, but didn't touch the RH hub. Friggin' thief. Same guy that told me my GN needed new ball joints - wouldn't align it otherwise. Ball joints are fine, took it somewhere else to have it aligned with no problems. STS Tire Centers in NJ - stay away from them.
But I digress. I'll dig deeper into it tomorrow, but I got the up-top work done and am now working on dismantling the suspension.
The engine support bar installed:
Close up of the special bracket for the left cylinder bank:
Working on the LH side:
Not sure why it's puking grease everywhere:
I'll put up some more tomorrow.......loads of fun!
Jim
  #2 (permalink)
Old 03-02-09, 06:55 PM
View Ranger's Photo Album
Casino Cash: $24291
Re: Finally started my TCC solenoid replacement today
That green grease is from your CV joint. The boot is ripped somewhere.
  #3 (permalink)
Old 03-02-09, 07:36 PM
turbojimmy's Avatar
BAD EMAIL ADDRESS
Casino Cash: $2150
That's what I figured. It's interesting how the centrifugal force stacks it all so neatly around the boot. I'll add a boot to the list of things I need to finish the job. I broke the stabilizer link on that side, too. And I need a front motor mount. And an oil cooler line. It'll be like a new car when I'm done!
Jim
  #4 (permalink)
Old 03-02-09, 08:49 PM
Casino Cash: $24291
I can't see the clamp on the inboard side of the boot. If that is what came off you might be able to get some CV joint grease put it in and reclamp it. I did that once by cleaning out a grease gun and filling it with CV grease. I used a needle attachment on the gun and refilled it. Used a big hose clamp to clamp it on.
  #5 (permalink)
Old 03-02-09, 11:25 PM
dirt_cheap_fleetwood's Avatar
Redneck with class
Cadillac(s): 1990 350 Brougham (Its big), 1988 Mark VII LSC (Its fast)
View dirt_cheap_fleetwood's Photo Album
Casino Cash: $12660
I want a lift in my garage!
"I treasure my remark to my grandson who asked, 'Grandpa, were you a hero in the war?' Grandpa said, 'No... but I served in a company of heroes.'" Sgt. Mike Ranney, quoted by Maj. Richard Winters
  #6 (permalink)
Old 03-03-09, 08:12 AM
turbojimmy's Avatar
BAD EMAIL ADDRESS
Casino Cash: $2150
The clamp is still on there - just can't see it in the pic. It must be torn somewhere. The factory replacements require a special tool to clamp them on, I think. But a hose clamp is a good idea.
It does come in handy. It's a little tight in my garage, but it gets the job done. I usually use it for parking (can put 2 cars in that one bay). For repairs, a 2-post would be better but they take up more space and are more complicated to install. The 4-post is free standing. I set the Caddy down on jackstands on the lift and can get it at a comfortable working height. Makes it easier to get the trans and engine cradle out when the time comes, too.
Jim
  #7 (permalink)
Old 03-03-09, 09:31 AM
View JVRudnick's Photo Album
Casino Cash: $2135
Just a quick question - is this TCC item the same one as is reported by running the codes and receiving this one -- PCM p0741 current - P0741 - TCC System Stuck Off
I ask in that it appears that my own TCC item is somehow reporting itself as faulty...course, when I reset all the codes that one has neve shown up again....
Oh, and I was told that this "fix" to the TCC item was a $20 part but $2000 in labour just to get it done....is that true too?
Jim
  #8 (permalink)
Old 03-03-09, 09:59 AM
turbojimmy's Avatar
BAD EMAIL ADDRESS
Casino Cash: $2150
Jim
Yes and yes. P0741, and the occasional P1860. $20 part, $2000 in labor. Transmission has to come out, or at least dropped down far enough to get the side cover off of the transmission.
I still can't get the RH axle nut off, and can't get the axle shaft out of the LH side. This is becoming a pain in the butt. I need to find an axle shaft removal tool locally. Not sure what I'm going to do about that nut yet. I've been hammering on it with an impact wrench all morning.
Jim
  #9 (permalink)
Old 03-03-09, 04:02 PM
Redneck with class
Casino Cash: $12660
Is the TCC solenoid the one that locks the torque converter at highway speeds? In my FSM they call it a VCC Lock Solenoid.
  #10 (permalink)
Old 03-03-09, 04:32 PM
99Classillac's Avatar
Cadillac Owners Enthusiast
Cadillac(s): Ex-99 Deville owner, Now-04 DTS owner, and a 07 ZX6R pilot
View 99Classillac's Photo Album
Casino Cash: $707
Looks like fun. As for your CV Joint, it might be more beneficial in the long run to just replace the CV Joint. Their cheap as hell, like $50 on RockAuto.com. I replaced them on my old 99 Deville on both sides. I'm just saying because who knows how long the boot has been torn and what dirt got inside. You can clean it out and replace the boot, but I would rather just buy a whole new shaft. At least the new shaft will be new with no wear on it either. Just my opinion.
  #11 (permalink)
Old 03-03-09, 06:00 PM
turbojimmy's Avatar
BAD EMAIL ADDRESS
Casino Cash: $2150
Yes, the TCC solenoid is the one that locks the converter at highway speeds. Not sure why your FSM would call it a VCC. TCC = Torque Converter Control solenoid.
Great fun indeed. I will definitely replace that axle shaft. My brother gave me the same advice. He came over and got all medieval on it and was able to remove the axle shafts with a crowbar. I was able to jump up and down on my 1/2"-drive breaker bar and free up that axle nut. In between looking for a job (got laid off a couple of weeks ago), I was able to do this:
Tomorrow the trans comes out!
Jim
  #12 (permalink)
Old 03-03-09, 06:54 PM
Casino Cash: $24291
Earlier ones where called VCC (viscous Converter Clutch). Obviously they worked wit a viscous fluid. Later ones are electronic, thus TCC (Torque Converter Clutch). TCC's lock up at 41 MPH. Don't remember about the VCC's.
  #13 (permalink)
Old 03-04-09, 02:28 PM
turbojimmy's Avatar
BAD EMAIL ADDRESS
Casino Cash: $2150
Ugh. This thing kicked my arse today. What a total pain in the nads this thing is. All for a $20 solenoid. But, the hard part is over. Need to order up the parts. I waited to see what else I broke before I ordered anything.
The clearance between the trans is zero on both sides. Unbelievable. Jammed up against the frame rail on one side and the flywheel on the other. But, it's out. My brother said "wouldn't it be a hoot if replacing the solenoid didn't clear the SES light?". No, it wouldn't.
Jim
  #14 (permalink)
Old 03-04-09, 03:19 PM
turbojimmy's Avatar
BAD EMAIL ADDRESS
Casino Cash: $2150
So, got the parts from the dealer.
The new axle listed for ~$400, my cost was $250 so I said forget it. Got a new boot instead. If the axle does go bad, it will be a walk in the park compared to this transmission job.
The source of the oil leak appears to be the oil pan, which the dealer told me is common. The parts guy told me that they recommend a new car when people bring in their Northstars with leaky oil pans. Since the cradle and transmission are out of the way, I decided to replace it while I had access to it. $150 worth of parts since it requires: new gasket, 2 new baffles and a new pickup tube.
Got a new power steering hose for the pressure side. It was leaking pretty bad, which explained the melting plastic smell all the time (burning power steering fluid).
New front motor mount, LH stabilizer link, side cover gasket for the trans, and of course the offending TCC solenoid.
This has been by far the crappiest repair job I've ever undertaken, and that's saying a lot. I'll never do it again.
Jim
  #15 (permalink)
Old 03-04-09, 05:07 PM
Casino Cash: $2135
just wanted to add, Jim...that as a totally NON fixit guy, I've muchly enjoyed these pix and your comments....
good on you! I hope that you get her all back together and she runs fine for like a decade or two....
me? Oh, I'd be paying my mechanic for all of this...course, the SES lite's been off now for like 10 days or so....so I'm hoping that myown TCC warning "fixed itself!"
Jim
Tags: , , ,
finally, replacement, solenoid, started, tcc, today
