Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: Broken Antenna trunk mod
Old 03-01-09, 10:17 PM
Cadillac(s): DeVille
View upgraded ninja's Photo Album
Casino Cash: $310
My nylon cable snapped (antenna would not go down) so I removed the motor from assembly . I kept the telescoping rods and installed (with no motor) it under the black lining on the roof of the trunk. Now I don't have to worry about it breaking or the motor going up and down. I used zip ties to secure to the cross brasses that run behind the speakers and wrapped everything in a towel to prevent shorting and vibration. The audio quality is just as good as when the antenna was fully extended. I glued the finial to the black screw insert so that it looks stock from the outside. When you screw the black lining back on you cannot tell that the antenna is under it. I originally bought the replacement nylon cable, but it still wasn't working properly, the antenna setup is way over engineered, so I just simplified it.
1995 DeVille
  #2 (permalink)
Old 03-02-09, 12:33 PM
N* Headgasket Survivor
Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold)
View chubbyranger's Photo Album
Casino Cash: $2200
Re: Broken Antenna trunk mod
Clever I just kept rebuilding mine in my 1990 even though I rarely listen to radio. This would have been a good alternative.
Tags: ,
antenna, broken, mod, trunk
