Need Help From Thailand
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Need Help From Thailand in Past Cadillac Vehicle Discussion; Dear All, First of all, I would like to thank all of you who helped me solved my problem with ...
    Winn is offline Cadillac Owners Member
    Apr 2004
    10
    Dear All,
    First of all, I would like to thank all of you who helped me solved my problem with my blower that did not want to stop even when I turned off the iginition. My sister mail blower control module and it is working well now. Now another problem just occured on my 1990 Deville. The ABS light is on. Not all the time but most of he time. What can I do? I wish there is a plae in Bangkok that can fix this. Where to look first? Please help
    Here is what I have done...I have checked connections from the box to the pump to two relays. I noticed that when I pump the paddle 25 times like when you want to check brake fluid the light would off. Then a few seconds later will come on again. Please help
    Thanks..Winn
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: Need Help From Thailand
    What about the brake fluid level at the reservoir at the master cylinder?? Is it low possibly.?? Frequent cause of the brake warning light.
    Apr 2004
    10
    Dear All,
    I just found out that I have "75" on the code for ABS. What else can I do? I also noticed that the plastic shield on the WSS cables are all broken up. Can this be the cause? Should I order new sensors? Pleas Help
    Winn
