Cadillac DeVille 1985 to 2005 including: 1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille, 1985-1992 Fleetwood and 1993 Sixty Special. | Cadillac Forums: Service Engine Code P0452 Please Help!!!
02-17-09, 10:44 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Service Engine Code P0452 Please Help!!! Hello, i got this code P0452 . How do i get rid of it? I took it to autozone scan came up to be a fuel pressure sensor???? I dont know where to start with this. What can i check and where is it located.....Please!!! i need your help! Thanks any help is appreciated! |
02-17-09, 11:02 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Service Engine Code P0452 Please Help!!! Depends on what car, year, and engine.
You do not need to take your car to AutoZone for a scan: the entire process is already built into the car.....read the stickys at the top of several of these forums entitled "How to pull Codes" and "Got codes ? Look here".
Fuel pressure sensor does not compute.......Fuel tank pressure or fuel pressure regulator gets closer......
EDIT.....For 2002 (OBD-II) P0452 refers to fuel tank pressure sensor. Several recalls and fixes on this here and in Seville over the past few years. Involves gas caps, fuel filler pipe rust, sensor malfunction, and EVAP system operation checks. |
02-18-09, 03:52 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Service Engine Code P0452 Please Help!!! Hey, yeah sorry....I know how to get codes from the cluster but last time I did that I drained my battery, also my car is a 1998 deville with the n* 4.6, I looked under the hood for loose connections and I could not find the evap sensor but I did find a hose connected to the engine on the left side lookin at the front of the car......on the other end of the hose there was a cap...? Idk what it is or if its even supposed to be there....its right near the fuel lines comming in......and it reaches to about the top of the strut tower brace.....also when I'm driving down the road and if I lay into the gas the car bogs and I can hear the air box gaspin for air......any help wouuld be appreciated plaease thanks |
02-18-09, 10:17 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Service Engine Code P0452 Please Help!!! You are going to have to be more specific on that hose with a cap unless Sub has any ideas. A picture would help.
I understand the bogging part, but gasping for air? A bad TPS will cause it to bog when nailed, but that should set a DTC. |
02-18-09, 10:35 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Service Engine Code P0452 Please Help!!! Has any work been done to the air box, filter, intake hoses, MAF or near the throttlebody ? That area would sound like the engine is gasping for air. (????)
The fuel tank pressure sensor is a different problem. |
02-18-09, 11:30 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Service Engine Code P0452 Please Help!!! Ill try to get a pic of the hose tomorrow. I can hear the air rushing when it bogs like its choking....i recently had the starter replaced......Thanks for the quick replys i really appreciate it..... |
02-18-09, 11:51 PM
| | Cadillac Owners Connoisseur Cadillac(s): '98 STS | | Join Date: Sep 2003 Location: Atlanta area | | | Re: Service Engine Code P0452 Please Help!!! Quote:
Originally Posted by pearlydeville Ill try to get a pic of the hose tomorrow. I can hear the air rushing when it bogs like its choking....i recently had the starter replaced......Thanks for the quick replys i really appreciate it..... | So the intake has been removed and replaced. Did the P0452 problem show up immediately after that repair?
If so, it could be the evaporative system parts and hoses were not replaced properly. |
02-19-09, 08:04 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Service Engine Code P0452 Please Help!!! yes after the repair it showed up i planned on taking it back to my mechanic but id rather save the trip if its something i can do on my own.....ill post up some pics today of the engine compartment.....thanks |
02-19-09, 08:47 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Service Engine Code P0452 Please Help!!! I have not been able to take pictures....sorry but i showed a mechanic and he said it could be the intake gaskets...he said they are little orings.......im not sure on how accurate that is. but can someone show me what the evap sensor looks like? and where it would be located? so i can see if there are any loose connections.... thanks.... |
02-19-09, 10:10 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Service Engine Code P0452 Please Help!!! There is no EVAP "sensor". EVAP is a system. Evaporative emission control. It stores fuel vapors from the tank and then burns them when the car is started. The sensor Sub mentioned is in the fuel tank. |
02-19-09, 10:17 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Service Engine Code P0452 Please Help!!! Replaced starter motor.......removed intake manifold........so the most likely culprits are: Intake manifold gaskets, Intake to throttlebody connection, manifold overpressure valve, PCV dirty air vacuum fittings, injector O-ring seals. |
02-20-09, 08:02 AM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: Service Engine Code P0452 Please Help!!! I think you have more than one problem here.
The code should be related to the fuel tank pressure sensor. It is usually mounted on top of the sending unit on the tank.
For diagnosis and repair on your car I am pretty sure that calls for removal of the tank.
It could very well be a bad sensor.
It should not be related to the repairs you had done.
You could have driveability problems related to the starter install.
If someone took a shortcut and didn't replace the intake seals they may have created a vacuum leak.
This shouldn't really cause lack of power but it could cause a high or unstable idle and/or codes to set for a lean condition.
Whatever is going on with the engine should not be related to the pressure sensor.
__________________ Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group. |
02-20-09, 11:25 AM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Service Engine Code P0452 Please Help!!!  Hey, Bill............How goes the war ??? Was over on Braddock Road the other day......short string, no time to stop in. Jim |
02-21-09, 09:41 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Service Engine Code P0452 Please Help!!! Im going to take it back to my mechanic and have him deal with it...... |
02-25-09, 08:36 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Service Engine Code P0452 Please Help!!! It was the intake gasket.....fixed the problem...thanks guys | | Cadillac Discussion Tools | | |
Censor is ON | | | |
