Finally~
Page 1 of 4 1234 LastLast
Results 1 to 15 of 51
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Finally~ in Past Cadillac Vehicle Discussion; Wow, first of all, Thank You all for the advice I've siphoned from this forum for 2 years without being ...
    97Purlwhyte's Avatar
    97Purlwhyte is offline Cadillac Owners Member
    Automobile(s): 97 Deville N*, 2005 CTS V6
    Feb 2009
    Miami, FL
    97
    Finally~
    Wow, first of all, Thank You all for the advice I've siphoned from this forum for 2 years without being a member.
    Now that I'm official here's my problem.
    My 97 deville is awesome, God bless the little old man who never smoked in it and had all the service done at the dealer when he had it.
    I've had it almost 5 years (May04) and really only had one major issue (tensioner pulley)
    Now it seems to want to act up on me... It wouldnt start everytime for a couple weeks. Me not being what you would call a 'car" guy took it to the shop. Shop says its the starter. In order to save, I buy a starter on EBay, (Mine was 69.00, dealer wanted $400) seller was 99.8 positive for starters, solenoids, ATV,Car, Truck, Boat whatever so I trust the part.
    Pay shop 3 bills to install starter, it works great for 2 days then bam, leaves me at KFC during lunchbreak. I come back after lunch, it starts. I drive home, come out the next morning for work, it starts fine. I make a short trip while at work, come out.. won't start. And there it sits.. I had to leave it.
    Could it be that I've fallen victim to the old "crappy starter" trick?! It looked brand new.
    Or have I fallen for the old "mechanic full of bs" trick. where my car has a problem, I pay to get problem fixed, problem returns like we fixed the wrong thing.
    I'm broke, the starter people have agreed to send me another starter but it wont go in for free. Should I trust the mechanic to install another one? Or should I find a new mechanic?
    Is there some problem known to Devilles that looks, acts, like a starter but can be fixed by average joe with a screwdriver?!
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: Finally~
    It sure sounds like a poor battery connection to me, unless it's security related.
    69
    82,155
    Re: Finally~
    I doubt that there is anything wrong with the starter or that it was the problem in the first place if it is cranking (I assume it is and was?). If that is the case, might want to check the fuel pressure, especially when it won't start.
    Mark C's Avatar
    Mark C is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Seville STS, 2000 Seville STS
    Jul 2007
    59
    1,693
    Re: Finally~
    I'd check the positive and negative battery cables. Sounds like a bad connection, or cable as its only happening when the car is warm.
    Feb 2009
    Miami, FL
    97
    Re: Finally~
    Quote Originally Posted by cadillac_al View Post
    The mechanic told me he cleaned both posts and the voltage across them went up dramatically. The battery is a die Hard gold and it's less than one year old. even after he cleaned the posts, the intermittent starting continues. When it wont start, I just get a "click" when I turn the key. All chimes, dash lights, radio, headlights work when it wont start.
    The car left me at work on Tuesday, of course after it sat all night and all day Wednesday, it started up just fine. I drove it home, parked and it started this morning.
    CaptainFishpond's Avatar
    CaptainFishpond is offline Banned
    Automobile(s): 99 DeVille (Grace Slick)
    Jul 2006
    Cleveland
    31
    333
    Re: Finally~
    Id hook it up to a battery box, or try to jump if. If it starts up with no problems look at getting a new battery.
    Feb 2009
    Miami, FL
    97
    Re: Finally~
    I'll look into that.
    Thanks everyone!
    This board is AWESOME!!
    69
    82,155
    Re: Finally~
    In that case, forget the fuel pressure. If there was corrosion on the posts, then check the cables. It may have worked it's way under the insulation.
    Feb 2009
    Miami, FL
    97
    Re: Finally~
    I've heard coca cola dissolves that, is that the only way to clean it?
    Jul 2006
    Cleveland
    31
    333
    Re: Finally~
    You can wire brush them clean, then throw some bulb grease on them.
    69
    82,155
    Re: Finally~
    Baking soda and water does great job and leaves no sticky mess.
    Feb 2009
    Miami, FL
    97
    Re: Finally~
    Thanks guys... I'll try the baking soda/water mix. It started up again today, seems as long as it can cool off for a couple hours it's fine. If I park, run in and come back in say 20 minutes... it won't start back up.
    I'm going under the hood this weekend.
    Chuwee's Avatar
    Chuwee is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac Deville 1990
    May 2007
    Houston Texas
    50
    266
    Re: Finally~
    Are you willing to remove the starter by yourself? It is not hard and if you do you can take it to Autozone and have them test it for you.
  16. #14
    Feb 2009
    Miami, FL
    97
    Re: Finally~
    Quote Originally Posted by Chuwee View Post
    Really?! The mechanic told me it was difficult. Something like "removing the whole intake" and blah blah blah. Although, it only took them start to finish about 2 hours. That's tow, drop, fix, test, and call me...
  17. #15
    69
    82,155
    Re: Finally~
    The starter IS under the intake, but it is not hard to get at. If it only clicks when it is warm and starts fine when cold, I would replace the solenoid while you have the intake off. I've had that happen once where the solenoid would get hot and contacts would expand and loss contact. Once it cooled down, the contacts contracted, made contact again and it would start.
  18. Remove Advertisements
