What size rims to get for a 1995 DeVille?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Like Tree2Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, What size rims to get for a 1995 DeVille? in Past Cadillac Vehicle Discussion; I searched and searched, but I found a lot of useless answers while going through several threads! I am thinking ...
    Krazy is offline Cadillac Owners Member
    Automobile(s): 95 DeVille
    Dec 2008
    21
    I am thinking about putting 20inch rims on the 95 DeVille, so I am looking for someone to point me into the right direction on the size tires and rims. I'm all up for suggestions too on what would look good. Thanks
    Here's a pic of the lac currently, post some rims and i'll photoshop them onto it.
    pompste is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 SEDAN DEVILLE-4.9 & 1978 SEDAN DEVILLE-425
    Jan 2007
    1,673
    Re: What size rims to get for a 1995 DeVille?
    Nice looking Deville! Before you put 20" rims on i hope you realize wheels that big will throw off your speedometer/odometer accuracy for sure.Probably will have to put different brakes/calipers on it also.It will cost some $$$.
    Last year i had Belle Tire try to put 16" chrome rims on my 1995 Deville and they would not even fit over the stock brake pads.Considering all the modifications and $$$ i would have to throw at it just to make bigger wheels fit properly,i got a refund on the wheels and stayed with the stock 15" wheels.
    There are other older posts in the forum that explain in more detail the problems created when putting on much larger wheels.It can be done if you`ve got big $$$ to throw at it------you can also forget about your cushy Caddy ride with 20" rims.Sorry to rain on your parade----i`m just stating the facts.
    Honestly,your Deville looks great with the stock wheels!
    Good luck if you decide to go bigger!
    dirt_cheap_fleetwood's Avatar
    dirt_cheap_fleetwood is offline Cadillac Owners Master
    Automobile(s): 1990 350 Brougham (The cruiser), 1988 Mark VII LSC (The DD)
    Aug 2007
    Woodridge, Illinois
    27
    5,545
    Stick with the factory wheels, PLEASE! If you want different wheels, at least stick with the factory size. I am tired of people tellin' me to throw some "DUBS" on my "'Lac." Its so stupid. Also, these cars do not have the best track record with transmissions. My '95 had only 54k miles on it when the previous owner had the trans rebuilt. Putting on larger wheels dramatically increases strain on the drive train and it could easily destroy your trans in a hurry.
    Brizzal's Avatar
    Brizzal is offline Cadillac Owners Enthusiast
    Aug 2007
    West Palm Beach, FL
    28
    847
    i have 17" black rims on my cady, no problems with the other than a little rub on the passenger tire while fully turning left
    Ghost C's Avatar
    Ghost C is offline Cadillac Owners Fanatic
    Automobile(s): '91 Sedan DeVille Silhouette Special
    High Point, NC
    30
    439
    Please don't put 20's on your car. Get yourself some 17's with appropriately sized tires. For example, a 205/70/15 is equivelant to a 215/60/16 (roughly) when upsizing to 16's from 15's. If you go from 215/60/16's to 225/50/17's, you should be fine. This is called a "plus one" by major chains, or if upsizing two inches for rims, a plus two.
    20's look like ass on any DeVilles except the newest body style, and even then the look is debatable and subject to scrutiny. Besides that, 20's are so 2005-2007. VIP style is in for 2009, and it calls for 17's and 18's with deep lip. Yes, you can have lip on the FWD Cadillacs. Ever taken a look at how far in the factory wheels sit? Running a lower offset wheel with a 2 or 3" lip will make the wheels sit even with the side of the car, and will stop any rubbing issues one might encounter.
    The key to styling modifications is to enhance, not overdo.
    dchavezo likes this.
    Dec 2008
    21
    Thanks for the posts guys, I see all the lac lovers here do not like the bigger rims. I guess i'll get some nice 17's, would be a lot better on my pockets too . Suggestions?
    quins90lac's Avatar
    quins90lac is offline Cadillac Owners Enthusiast
    Automobile(s): 1990 Cadillac sedan devile
    May 2008
    Peoria IL USA
    35
    616
    would yo be able to put say 18's on a 90 or should i just go with some thing like a 16 or 17 .ide stick with the stocks but i just dont realy car for them and thire kinda beat up , so i was thinking about a set of 18 inch AR casinos
    Ghost C's Avatar
    High Point, NC
    30
    439
    Just check your rolling diameter. Most DeVilles have something like a 26" diameter on the tires (ie 205/70/15), so you can fit dumb big wheels on the car as long as the width isn't excessive. Doesn't mean you should put the biggest possible wheel on the car though.
    delatorre1986 is offline Cadillac Owners Member
    Automobile(s): 1996 Deville 1985 Fleetwood
    Jun 2006
    TX
    74
    It is true the car will ride like a pinto without shocks...but hey if you want some bling on your ride I say go for it, at least your not driving a riced out Honda or something. Just make sure to have your car's wheels aligned with the aftermarket rims on and balanced.. never had issues with the brakes, the rims are heavier then the stocks. Wish I still had that car.. Have the car painted with chameleon mine would change from orange red to yellow if the sun hit it at a angle.
    quins90lac's Avatar
    May 2008
    Peoria IL USA
    35
    616
    well i was thinking 18's but i cant get white walls in 18 so ill probably go with like 17's and probably a 205/55/17 tire i just mainly want to kind of dress it up and make it stand out more
    Mattillac's Avatar
    Mattillac is offline Cadillac Owners Fanatic
    Automobile(s): '95 Sedan DeVille
    Aug 2005
    San Antonio, TX
    29
    199
    Quote Originally Posted by pompste View Post
    Hate to disagree with you but your facts aren't totally correct... to the OP - as long as you retain the correct aspect ratio for your wheels, you shouldn't have a problem. I upgraded to a set of 20" wheels with Lo-Pro tires about 6 months ago, and they are physically the same size as my old wheel/tire setup, so the odometer/speedometer performs correctly without any modification.
    My brake setup is more than sufficient for these wheels (if you live in an overly wet climate I might suggest upgrading to ceramic brake pads at the least, but you should be fine with stock setup).
    As for the ride, the suspension stays the same no matter what wheels are on the car so your "bounce" quality will stay the same, although you will feel more of the road. Kind of hard to explain unless you've experienced it.
    In the end, it's your car and ultimately your decision on what it looks like (I would advise against anything over 22's though)
    Here's my car with her 20" rims, no issues with rubbing, stopping, speedo, etc. they fit perfectly
    Se7enCapadon is offline Cadillac Owners Member
    Mar 2014
    1
    What size are your tires, will 245/30/20s fit?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    This thread's been dead for 5 years, and mattillac hasn't posted in about as long.
    Please feel free to start your own thread.
    245/30/20 is about 1" too small in outside diameter.
    pompste likes this.
  16. #14
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,365
    Quote Originally Posted by Se7enCapadon View Post
    your original tire was/is 215/70/15 -
    you want to keep the overall diameter
    as close to the original - 26.85 inches - as possible -
    you can't go too crazy on width either -
    215 was stock - 235 is 3/4 of an inch wider -
    go much wider than that - and you start rubbing -
    so 235/35/20 is about as close as you can get -
    though it is somewhat smaller in overall diameter - 26.48" -
    the wheel offset will be CRITICAL - and will determine whether or not -
    you will have problems with rubbing -
    not a good match -
    compared to stock -
    it is too wide - a full 1 1/4 inch wider - so it will probably rub -
    and the overall diameter is more than an inch smaller -
    the speedo will be off -
  17. #15
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,431
    Wheel size won't affect the speedometer, like others have pointed out it's the overall diameter of the tires that will.
    Also strange someone said 16" rims won't fit since they came on that body style. Strange things happen when you just start throwing wheels at cars and don't check any clearances first.
    And now to find my way back to 2014 somehow?
  18. Remove Advertisements
