Coolant Flush
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Coolant Flush in Past Cadillac Vehicle Discussion; I have a 98 Deville with 105,xxx miles on it. I just got it and realize it needs a coolant ...
    mrpib is offline Cadillac Owners Member
    Automobile(s): 1998 Deville
    Dec 2008
    37
    14
    Coolant Flush
    I have a 98 Deville with 105,xxx miles on it. I just got it and realize it needs a coolant flush. I have done this before myself on other vehicles. I have used the Prestone back flush kit you buy at Wal-Mart. I feel a little weird about leaving that plastic tee in the heater hose from now on.
    1.) Does anyone use this Prestone back flush kit and leave the tee in and life is good?
    2.) I need information about the tabs that I need to get and where I need to put them?
    3.) Do most of you put back DexCool or GM approved Prestone DexCool?
    4.) What else do I need to know about this?
    [NortHStaR]'s Avatar
    [NortHStaR] is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Cadillac DeVille
    Aug 2008
    Phoenix, AZ
    24
    279
    Re: Coolant Flush
    For coolant tabs, check this post out:
    http://www.cadillacforums.com/forums...now-about.html
    I use GM approved prestone dex because it is less corrosive
    68
    81,926
    Re: Coolant Flush
    Don't flush it. You won't get all the coolant out. If you flush it then you won't get all the water out so unless you use a refractometer, and keep adjusting, you'll never have 50/50. Just drain and refill 50/50 Dex/distilled water.
    Dave S Texas's Avatar
    Dave S Texas is offline Cadillac Owners Enthusiast
    Automobile(s): '87 Coupe DeVille 4.1L FWD(New engine '08) 1981 F100 '03FXDL
    May 2008
    Austin(area), Tx
    73
    876
    Re: Coolant Flush
    The tabs can be bought at any GM dealer or at an AC-Delco parts store. The Delco part# is 10-108 and a the packet of 5 tabs is under $2. GM part# is 3634621 and more than $2.
    I used that Prestone flush kit 15/more years in my '81F100. Same T in place today. Installed a kit in my DeVille about 8+yrs ago and I flush the system in the car every two years and drop in another pack of tabs....3 in the lower hose, 2 in the radiator....crushed up good. My engine uses the Green AF.
    Dec 2008
    37
    14
    Re: Coolant Flush
    Is there a post that shows this process? I would like to get some correct information about which hose is which.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,915
    Re: Coolant Flush
    I doubt there is any place to even cut and mount the Prestone capped T fitting, and it isn't necessary.
    There are no block drains in a Northstar, so about 3 quarts of coolant always remains in the system. The ONLY way to completely exchange all the present 50/50 DEXCOOL mix is to use a vacuum operated coolant change machine.
    The "upper " radiator hose leaves the water pump crossover housing and enters the passenger side radiator tank. The "lower" hose leaves the middle of the driver's side tank and enters the water pump cover.
    The 1" line which leaves the bottom of the surge tank carries essentially no flow: it only allows the surge tank to "float" on the system.
    Most of the smaller (5/8" and 3/4") heater and bypass hoses are essentially inaccessible.
    Personally, I would never insert a flush fitting into a Northstar system. It isn't necessary and the coolant change intervals are 4 - 5 years apart.
    Want it done correctly ??? Use a dealer spring special and spend the $125 to do a proper coolant change.
    Dec 2008
    37
    14
    Re: Coolant Flush
    I went to the dealer and had the coolant system serviced. I asked if they used the tabs and they said that those are no longer standard operating procedure. I asked if they would use them anyway and they said they would about 20% of the customers requested them.
    I asked for a flush and the tech came to me and said he recommended a drain and refill as opposed to a flush. I accepted his recommendation of a drain and refill. Was that a good thing to do?
    I also got the transmission fluid flushed.
    I got both of thoe for $308.00 and I didn't get dirty. I walked across the street and shopped at Lowes. I'm pretty pleased, if they did their job correctly.
    68
    81,926
    Re: Coolant Flush
    Too bad you didn't do it the other way around. I'd rather have seen the coolant flushed than the trans. The only thing I would flush is a toilet and I won't use tabs in IT either.
  11. Remove Advertisements
