Cadillac DeVille 1985 to 2005 including: 1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille, 1985-1992 Fleetwood and 1993 Sixty Special. | Cadillac Forums: 95 deville 4.9 with 4t60e
01-11-09, 04:49 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | 95 deville 4.9 with 4t60e Has anyone removed the 4t60e automatic transmission from a 94 or 95 Deville witha 4.9 engine? Mine needs to come out and I want to know what is the best procedure.I have been told you can pull it without removing the engine .I have also been told that you do have to pull the motor . Any help is appreciated. Thank you |
01-12-09, 03:56 AM
|  | Redneck with class Cadillac(s): 1990 350 Brougham (Its big), 1988 Mark VII LSC (Its fast) | | Join Date: Aug 2007 Location: Woodridge, Illinois Age: 19 | | | Re: 95 deville 4.9 with 4t60e If you have a lift it can be dropped out the bottom but its no easy chore. You have to literally take the entire front of the car apart and brace the sh*t out of it so the unibody doesn't bend once you remove the engine.
__________________ "I treasure my remark to my grandson who asked, 'Grandpa, were you a hero in the war?' Grandpa said, 'No... but I served in a company of heroes.'" Sgt. Mike Ranney, quoted by Maj. Richard Winters |
01-12-09, 08:57 AM
| | Cadillac Owners Connoisseur Cadillac(s): Cadillac 78 Seville, 78 Coupe de Ville, 92 Sedan de Ville | | Join Date: Feb 2007 Location: Maine Age: 48 | | | Re: 95 deville 4.9 with 4t60e I'm sure there may be differing opinions on this. I have pulled a couple Buick engines without the transmission and I'm not sure if it's easier with or without the trans. However, I always told myself that if I had to change the transmission I would take it out WITH the engine rather than try to take it out by itself. Some people have taken out the trans by itself but they also reported that it was quite difficult and never any fun. I would use the same procedure on a Caddy 4.9 that I use on the Buicks. I would take the engine and trans out together. I would also replace the waterpump and timing cover while the engine was out.
I have to remove my engine this summer to replace exhaust manifold studs. It could be done on a lift but I don't have one and every shop I took it to was scared of it and wanted to quote me 10 hours labor. I may try to rent a bay this summer if I can. I mention this because you might want to make certain your exhaust manifolds are leak free if you do take the engine out. |
01-12-09, 09:35 AM
| | Cadillac Owners Member Cadillac(s): Cadillac Sedan Deville | | Join Date: Nov 2008 Location: Fort Wayne Age: 35 | | | Re: 95 deville 4.9 with 4t60e Thank God mine was changed right before I got it. It's a toss up and a matter of preference. Take them out together. I've dropped the cradle out of the bottom on a few cars and it was a breeze. Some guys will swear by going out the top. If you have a hoist, go top, an A-frame, bottom for sure. Good Luck! |
01-13-09, 02:32 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: 95 deville 4.9 with 4t60e Thanks Jay,Al, and dirt cheap.I welcome the advise.George |
01-13-09, 07:30 PM
| | Cadillac Owners Enthusiast Cadillac(s): 99STS,98 Deville Scrapped.1997 GrandPrix GTP | | Join Date: Nov 2005 Location: Port McNicoll, Ontario Age: 46 | | | Re: 95 deville 4.9 with 4t60e I agree on the removing all the components at once, just when you remove the tranny, have some help, this unit is very heavy and awkward to pickup |
01-14-09, 10:58 AM
|  | Cadillac Owners Fanatic Cadillac(s): 1990 Cadillac sedan devile | | Join Date: May 2008 Location: Milan IL USA Age: 27 | | | Re: 95 deville 4.9 with 4t60e Quote:
Originally Posted by jays94DE_Ville Thank God mine was changed right before I got it. It's a toss up and a matter of preference. Take them out together. I've dropped the cradle out of the bottom on a few cars and it was a breeze. Some guys will swear by going out the top. If you have a hoist, go top, an A-frame, bottom for sure. Good Luck! | se now i was going to do that A-frame thing on my 90 when the trany and the engien went bad in it but was told that it wouldn't work cause if the uni-body wer to get tweaked in any way that the car would be history. but then again the guy that told me that was the same guy that charged me $600 to put them both in and did some real shoty work a well. next time i have to do it im going to use that A-frame idea though and do it my self .cause im planing on puting in another engien and trans and rebuild them both before i put them in. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
