| Re: 93 DeVille Engine surging at idle I found a post that explains the operation of the ISC motor.
Its says,
"Description of ISC.
When the throttle is released it depresses the plunger on the ISC, this closes a switch in the
ISC to signal the computer that the throttle has been released and to go to the idle mode.
If the switch is not closed when the throttle is released, then the engine "hunts" and doesn't
know what to do, hence the ranging of rpms."
This sounds like my problem, the ISC is hunting because of dirty contacts. I will take it apart and try cleaning the contacts. |
