Cadillac DeVille 1985 to 2005 including: 1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille, 1985-1992 Fleetwood and 1993 Sixty Special. | Cadillac Forums: Oil change after 2000 miles?!?
01-07-09, 06:43 PM
| | Cadillac Owners Member Cadillac(s): 92' Sedan DeVille "Gold Key Edition" | | Join Date: Oct 2008 Age: 28 | | Oil change after 2000 miles?!? Hello all,
i changed my oil ~2000 miles ago and my oil life is at 8%. Is it really necessary to change the oil after 2000 miles? I know it depends on how u are drive etc....
Oil looks good, not really dark. So, what do u think?
(it's an 92' Sedan DeVille with 117.000miles on it)
Best Regards  |
01-07-09, 06:45 PM
| | Cadillac Owners Fanatic Cadillac(s): 1989 Cadillac Sedan Deville | | | | | Re: Oil change after 2000 miles?!? wow...what oil are you using, what ur mile, and how your driving ? fast? slow? etc |
01-07-09, 08:15 PM
| | Cadillac Owners Connoisseur Cadillac(s): 92 eldorado, 97 S.T.S.. | | Join Date: Nov 2005 Location: roberts creek b.c. canada | | | Re: Oil change after 2000 miles?!? Quote:
Best Regards  |
You do not have to change your oil after 2000 miles, when the oil was changed last time was the oil life indicator reset?. |
01-07-09, 09:26 PM
| | Cadillac Owners Member Cadillac(s): 92' Sedan DeVille "Gold Key Edition" | | Join Date: Oct 2008 Age: 28 | | | Re: Oil change after 2000 miles?!? Quote:
Originally Posted by bklynsoulja wow...what oil are you using, what ur mile, and how your driving ? fast? slow? etc | Hmmm... oil change was made by my cadillac dealer...( don't know why i wrote "i changed"  ) sorry, can't say what kind of oil.
I guess i drive like a grandpa....  10 miles every day to work.... no high rpm.... so far Quote:
Originally Posted by creeker You do not have to change your oil after 2000 miles, when the oil was changed last time was the oil life indicator reset?. | Yes it was.
01-07-09, 10:06 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Oil change after 2000 miles?!? I could understand this if you drove 2 blocks in winter and shut down. 10 miles should be enough to heat it up and you should certainly get more than 2000 miles. I would suspect it was not reset. I'd reset it again and watch it to see how fast it decrements. If it seems normal, then change it at 75%. |
01-07-09, 10:15 PM
| | Cadillac Owners Member Cadillac(s): 1992 DeVille | | Join Date: Jan 2009 Location: Willowrbook, IL Age: 29 | | | Re: Oil change after 2000 miles?!? New 92 Deville owner here, where does it show the oil life and how do i get it to display? |
01-07-09, 10:54 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Oil change after 2000 miles?!? Funny, I had a '92 Deville, but can't remember how to display it. Have you read the owners manual? |
01-08-09, 01:25 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 1991 Deville x 1/ 1992 Deville x 1/ 1993 Deville x 3 | | Join Date: May 2008 Location: Chicago, IL Age: 17 | | | Re: Oil change after 2000 miles?!? Press "range" and "fuel used" on the fuel data center to see the oil life reading.
If you press and hold "range" and "reset" it will set back to 100%. |
01-08-09, 06:12 PM
| | Cadillac Owners Member Cadillac(s): 92' Sedan DeVille "Gold Key Edition" | | Join Date: Oct 2008 Age: 28 | | | Re: Oil change after 2000 miles?!? ok, thanks guys.... i keep an eye on it.  | | Cadillac Discussion Tools | | |
Censor is ON | | | |
