Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: 95 Deville - Transmission shot?
Old 12-22-08, 09:23 PM
Cadillac(s): 95 Cadillac Deville
View marccaron21's Photo Album
Casino Cash: $285
Exclamation 95 Deville - Transmission shot?
I was driving on a highway earlier today and take my exit. As I speed up to pass someone, my car seems to slip out of gear, or into neutral. I pulled over, put it in park, and started to drive off again. For some reason, the car does not like to shift out of first gear. It'll slip into a neutral position and won't go anywhere. It also won't reverse. In fact, when I put it in reverse, there's a noise that's audible from the engine bay. It's a clinky noise, and sounds like popping popcorn.
The transmission fluid levels are fine, and the fluid itself did not smell burnt or look too dark. It kind of smelled like wax crayons. The motor runs fine. It just won't move out of first and it won't move in reverse at all.
What do you guys think happened? The car is a 95 Cadillac Deville with the 4.9L V8.
  #2 (permalink)
Old 12-22-08, 10:09 PM
View Ranger's Photo Album
Casino Cash: $24216
Re: 95 Deville - Transmission shot?
Not sure, but maybe shift solenoids. Have you pulled the DTC's? A failed shift solenoid should set a code.
  #3 (permalink)
Old 12-22-08, 10:32 PM
Casino Cash: $285
Nope, I haven't been able to get any trouble codes. I was more worried about getting home, haha.
How sure are you on the shift solenoids thing off hand? I'll know for sure once I'm able to scan it.
  #4 (permalink)
Old 12-22-08, 10:53 PM
Casino Cash: $24216
Not real sure of the solenoids based on your symptoms. No need for a scanner. Just press and hold the OFF & WARMER buttons to enter the diagnostics and get the DTC's. After your in answer yes to the prompts with the HI FAN button and NO with the LOW FAN button.
  #5 (permalink)
Old 12-22-08, 11:13 PM
Rodya234's Avatar
Cadillac(s): 1991 Deville x 1/ 1992 Deville x 1/ 1993 Deville x 3
View Rodya234's Photo Album
Casino Cash: $7685
I may sound like a broken record here, but if you don't get any codes the problem could be a stuck shift valve. I've had two 4T60-E's with this problem already, and the symptoms you describe sound exactly like the second one.
(The first one was having 2nd gear starts, but the solution to the problem was the same.)
  #6 (permalink)
Old 12-23-08, 09:41 PM
Cadillac Owners Enthusiast
Cadillac(s): 99STS,98 Deville Scrapped.1997 GrandPrix GTP
View Caddyshack100's Photo Album
Casino Cash: $6414
I agree with Rodya about the valve, however the noise you are hearing is probably your reverse reaction drum, the splines on it are probably damaged by now and that is also why you are not getting reverse, Have you tried to go manually from 1 to d through each gear? How many miles are on this tranny?
Tags: , ,
deville, shot, transmission
