Cadillac DeVille 1985 to 2005 including: 1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille, 1985-1992 Fleetwood and 1993 Sixty Special. | Cadillac Forums: The Car Mileage Thread
08-04-03, 08:24 PM
|  | Cadillac Owners Connoisseur Cadillac(s): '93 Fleetwood Brougham...Dad's | | Join Date: Jul 2003 Location: Southern DE Age: 23 | | | Our '93 Fleetwood Brougham only has 89.5k pampered miles, and looks and runs PERFECTLY. Nicer than some expensive new cars I've been in and around. There are a few new parts, but not much.
Our '92 Roadmaster Limited has 185k miles with EVERYTHING ORIGINAL, and both looks and runs like a car with 50-60k easy miles. The car is awesome and what pushed us to get rid of the '69 Chevelle and buy the Fleetwood. Some parts of the car I actually like more than the Caddy...but I think I like the Caddy a little more overall.
Our '02 Chevy Avalanche Z66 has 22k, which seems quite high to us, considering we've had it for a year and 3 months. It will be out of warranty next year already, but has been pretty much flawless.
Oh, I forgot to mention! The Buick and Caddy get about the best gas mileage of any vehicles we've ever owned. Despite being such big, heavy, V8-powered road warriors, they just barely sip the gas. Always around 25MPG, regardless of conditions....the Avalanche can only get around 15, sometimes close to 18 if cruising steady on the highway. I just don't understand it! |
08-05-03, 12:48 PM
| | Cadillac Owners Member | | Join Date: Jul 2003 Location: Minnesota | | | Re: The Car Mileage Thread! Quote: |
Originally Posted by thu Yeah, that describes my problem, too. It has to be warm outside. If it's colder, like 65*F, then it doesn't happen. A fella on another Caddy board said he had to replace the pickup screen in the tank and the fuel pump.
T |
Do you have this problem where your engine stalls or nearly stalls when you have less than like 5 gals of gas? It seems the fuel pump is having a hard time whenever there's little gas and nearly kills the engines when I come to an abrupt stop or when I make a righthand turn with little gas, as if the fuel pump can't seem to catch the sloshing fuel or something. This problem completely dissappears whenever there's more than about 7 gals of gas. |
08-05-03, 12:51 PM
|  | Cadillac Owners Fanatic Cadillac(s): 2003 Cadillac DeVille | | Join Date: Jun 2003 Location: Ontario, Canada Age: 24 | | | Re: The Car Mileage Thread! Quote: |
Originally Posted by blkchrry92dvl Do you have this problem where your engine stalls or nearly stalls when you have less than like 5 gals of gas? It seems the fuel pump is having a hard time whenever there's little gas and nearly kills the engines when I come to an abrupt stop or when I make a righthand turn with little gas, as if the fuel pump can't seem to catch the sloshing fuel or something. This problem completely dissappears whenever there's more than about 7 gals of gas. | I wouldn't bet thats the problem. Keep in mind that 5 gals is a quarter tank - thats 5 bags of milk - which is still a lot! If I remember correctky the reason it does that is a design flaw in the gas tank??? |
08-05-03, 01:12 PM
Originally Posted by 2dfx I wouldn't bet thats the problem. Keep in mind that 5 gals is a quarter tank - thats 5 bags of milk - which is still a lot! If I remember correctky the reason it does that is a design flaw in the gas tank??? |
That's what I was implying... no gas tank should have trouble like this, in fact, I haven't heard of any other car having this problem. It indeed seems like an inherent design flaw, but there's nothing I can or would like to do about it; I'll just try to top it off as often as I can, even though the additional weight of the fuel might lead to decrease in fuel economy, which should be minimal at best. |
08-06-03, 02:29 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 2003 STS, 1993 Deville, 1985 Deville | | Join Date: Jul 2003 Location: Wyoming | | | Re: The Car Mileage Thread! Quote: |
Originally Posted by blkchrry92dvl Do you have this problem where your engine stalls or nearly stalls when you have less than like 5 gals of gas? It seems the fuel pump is having a hard time whenever there's little gas and nearly kills the engines when I come to an abrupt stop or when I make a righthand turn with little gas, as if the fuel pump can't seem to catch the sloshing fuel or something. This problem completely dissappears whenever there's more than about 7 gals of gas. | Well, I have this problem that when there's 5 gallons of gas or less and I come to a quick stop, then engine wants to die. The computer then tries to "stall save" it. I don't remember if making right hand turns with a little gas causes it too. It didn't used to do this until about a month ago. The problem does indeed go away when there's more than 5 or 6 gallons in the tank.
I think that:
- the baffles may have shifted
- the fuel screen in the tank is goofed up so that part of it is sticking up in the air when the fuel gets below 5 or 6 gallons
- the fuel pump is getting weak.
If it's any of these three, I think we can take comfort in the fact that if we have a couple of jackstands and a floor jack, fixing/replacing things isn't that difficult and not very expensive. I understand that a new fuel pump is $105 and a new screen is $13. As for the baffles, if they're broken, I'd suppose our recourse would be to go to a junkyard and get a used tank with the sender unit, pump, etc. I did that for my 1985 DeVille and it worked wonderfully.
Also, don't forget to checkout http://www.caddyinfo.com and look at the "Caddyinfo.com board". Make sure to make use of the "Searchable Archives". It's amazing the technical competence of the folks who hang out over there. Two of them helped design the computers in our Caddys!
You'll get good answers there. I post there, too as "TimHu".
T |
08-06-03, 03:44 AM
|  | Banned Cadillac(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII | | Join Date: Aug 2003 Location: Albuquerque, NM Age: 22 | | | Well back on the mileage subject, my 75 Sedan DeVille has 116k and used to run perfectly. When the distributor problem is fixed, I'm confident it will run perfectly again. |
12-07-03, 06:18 PM
| | Cadillac Owners Fanatic | | Join Date: Jan 2003 Location: Planet Earth Age: 32 | | | I have just clocked one hundred thousand miles on my nineteen ninety four Cadillac Fleetwood Brougham. |
12-07-03, 08:37 PM
|  | Cadillac Owners Member | | Join Date: Nov 2003 Age: 54 | | | Re: The Car Mileage Thread! 55k on my baby blue 1990 DeVille - LOVE this car!!! |
12-07-03, 08:59 PM
|  | Cadillac Owners Connoisseur Cadillac(s): just one | | Join Date: Mar 2003 Location: Vacationland | | | Re: The Car Mileage Thread! Quote: |
Originally Posted by theodorei 55k on my baby blue 1990 DeVille - LOVE this car!!! | I have 221 miles on mine!:coolgleam  |
12-08-03, 11:25 PM
|  | Cadillac Owners Member | | Join Date: Dec 2003 Location: Monroeville, nj Age: 25 | | | Re: The Car Mileage Thread! 208k miles on my '91 deville and still runnin strong. |
12-09-03, 01:28 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 1995 Sedan Deville; 1990 Brougham | | Join Date: Aug 2003 Location: Milwaukee Age: 27 | | | Re: The Car Mileage Thread! Just hit 124,400 on the way to the club...
I small Oriental man started dancing with my Rican, Tito. I thought it was funny, Tito did not. |
04-18-04, 09:15 PM
| | Cadillac Owners Member | | | | | Re: The Car Mileage Thread! i have 113,000 miles on a 1986 deville ht4100 original engine. i take incredible care of this car and love it |
04-19-04, 04:55 AM
|  | Cadillac Owners Fanatic | | Join Date: Jan 2004 Location: North Dakota Age: 32 | | | Re: The Car Mileage Thread! :coolgleam 205,948!!! on my 91 Sedan DeVille, original 4.9 |
04-19-04, 07:38 AM
|  | Cadillac Owners Connoisseur | | Join Date: Jan 2004 Location: Amherst, NH Age: 22 | | | Re: The Car Mileage Thread! Quote: |
Originally Posted by Ralph Yeah, but our minimum wage is more!  | Damn you socialist Canucks!  Anyways, 84K on the deville, ain't goin
anywhere soon, 274,000 on me 350 blazer. Strong engine. I just changed the
pcv valve this morning, running 90% better, still has a couple quirks, but im not
complaining. |
04-19-04, 04:27 PM
|  | Cadillac Owners Fanatic Cadillac(s): 1996 SLS, 1985 Seville Commemorative Edition, 1969 Sed. Dev. | | Join Date: Feb 2004 Location: East Lansing, MI Age: 24 | | | Re: The Car Mileage Thread! '89 Sdv: 137000, '90 Sdv: 165000, '69 Sdv: 181000 | | Cadillac Discussion Tools | | |
Censor is ON | | | |
