Cadillac DeVille 1985 to 2005 including: 1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille, 1985-1992 Fleetwood and 1993 Sixty Special. | Cadillac Forums: Power antenna switch
11-30-08, 05:03 PM
|  | Cadillac Owners Member Cadillac(s): 94 Sedan DeVille, 07 Camry | | Join Date: Nov 2008 Location: Ontario, Canada Age: 38 | | | Re: Power antenna switch Thanks very much, Ranger. I just ordered a new one. |
11-30-08, 11:12 PM
|  | Redneck with class Cadillac(s): 1990 350 Brougham (The cruiser), 1988 Mark VII LSC (The DD) | | Join Date: Aug 2007 Location: Woodridge, Illinois Age: 20 | | | Re: Power antenna switch Quote:
Originally Posted by 94_SDV I wired a switch for the power antenna, and it is the dark green wire that gets hooked up to the switch. There are actually two dark green wires, and it's the wire going to the black connector, not the white one. I put the switch in the glove box below the lock out switch (see pic below, sorry it's blurry). It works like a charm. I also took the antenna apart from the mast down and sprayed white lithium grease down the shaft. Unfortunately, it still sticks! Not sure how it went from working fine one day, so being so sticky the next, but that's the way it is. Anyone know a good place to get a new power antenna? | That's an interesting place for the switch, very creative. Doesn't your car normally have the Traction Control Disable switch there? That's what was there on my '95 DeVille.
As for the antenna still sticking, did you try what I suggested and re-lubricate the mast itself, not just the gears and motor underneath?
__________________ "How far you go in life depends on your being tender with the young, compassionate with the aged, sympathetic with the striving and tolerant of the weak and strong. Because someday in life you will have been all of these." - George Washington Carver |
12-01-08, 12:47 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 1991 Cadillac Brougham, 1999 Camaro Z28 | | Join Date: Jul 2008 Location: Nashville, TN | | | Re: Power antenna switch I pulled the fuse for mine when the antenna was up. I think I need a new antenna/motor, but its a major PITA to replace on a 1991 Brougham, since it sits in the right front fender with no way to get to it.
I've seen on 70's vintage Cadillacs that there is a button to manually lower and raise the antenna. Pretty good idea IMO, saves wear and tear on the motor. |
12-01-08, 02:09 PM
|  | Cadillac Owners Member Cadillac(s): 94 Sedan DeVille, 07 Camry | | Join Date: Nov 2008 Location: Ontario, Canada Age: 38 | | | Re: Power antenna switch DCF, yes, I did. Many times actually, and it didn't help. I used mineral spirits to clean the mast an white lithium grease for the inside. Alas, it didn't work.
That was a free space in my glove box, I just had to pop out the plastic cover to expose the round hole. I don't have a traction disable switch. |
12-02-08, 01:04 AM
| | Cadillac Owners Member Cadillac(s): 1994 Concours, 2007 DTS Performance | | Join Date: Jan 2008 Location: Ellicott City, MD | | | Re: Power antenna switch i seriously can't believe mine still works. never did any maintenance or lubrication to it. I worry about it every time i hear it moving up and down! Does anybody know if i get a new head unit like a pioneer or alpine will it be able to function similarly to the factory stereo or will i have to install an override switch too?
thanks. great topic! |
12-02-08, 01:50 PM
Originally Posted by RobsDeville i seriously can't believe mine still works. never did any maintenance or lubrication to it. I worry about it every time i hear it moving up and down! Does anybody know if i get a new head unit like a pioneer or alpine will it be able to function similarly to the factory stereo or will i have to install an override switch too?
thanks. great topic! | Most aftermarket radios do have an output for the power antenna. If the one you are looking at does not then most have an output signal for an amplifier and you can also use this for the antenna. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
