I need to figure out this lean thing - P0171
Results 1 to 12 of 12
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, I need to figure out this lean thing - P0171 in Past Cadillac Vehicle Discussion; Ok so some of you may remember I was having a problem with an O2 sensor. That got replaced today. ...
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    49
    6,919
    Now what I have is P0171 - Fuel Trim System Lean Bank 1. As soon as I clear it, it comes back. A few times I got a few minutes out of it before the code reappeared but for the most part it comes right back.
    What should I be looking at here? Intake plenum, intake manifold. It's always bank 1 so I don't think it would be in the plenum or the runner from the air box. It would almost have to be the manifold, right?
    68
    81,723
    Re: I need to figure out this lean thing - P0171
    What year? I'd start by looking for a vacuum leak on that side first.
    codewize's Avatar
    Apr 2005
    Upstate NY
    49
    6,919
    This is the 01 DTS. I looked at all the lines going to the AIR pump, I looked at other hoses and such and I don't see anything funky.
    I also tried to spray that side of the intake but I used carb cleaner rather than starter fluid. Probably not the same effect huh.
    Kind of odd. I dind't take the car out yet today but I did let it idle for a bit with no codes.
  5. #4
    68
    81,723
    Carb cleaner should work just as well. Did you spray around the infamous plenum?
  6. #5
    codewize's Avatar
    Apr 2005
    Upstate NY
    49
    6,919
    OK so, today I drove for probably 30 - 40 miles. No codes. Then on the way home I got P0131 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 1. I cleared that and it stayed away.
    So I guess replacing the $80 sensor did nothing for me.
    What do you guys think.
    I did not spray around the plenum, I can't believe that all the codes would be on bank 1 if it was something that far up in the air stream.
    Let me ask this and correct me if I'm wrong. Bank 1 sensor 1 is the sensor in the rear bank manifold, correct? Rear bank being closest to the firewall. This is really driving me crazy now and it's starting to cost money.
  7. #6
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    you tell me which code youd like to know about and ill post everything ESI says on it haha
  8. #7
    68
    81,723
    Correct. I agree with your thinking about the plenum, but I'd check it to rule it out anyway. Otherwise it remains an unknown and a possibility.
  9. #8
    codewize's Avatar
    Apr 2005
    Upstate NY
    49
    6,919
    I'll check it tomorrow. I'm good with that logic. I'll also recheck the intake as I didn't go crazy because I was using cleaner and not starting fluid, so I didn't know what the result could / would be so I didn't go crazy.
    STS; I want to know about both of the codes I'm getting. P0171 and P0131
  10. #9
    codewize's Avatar
    Apr 2005
    Upstate NY
    49
    6,919
    Shes going in on Wed to be looked over
  11. #10
    VICDMAC31 is offline Cadillac Owners Member
    Automobile(s): Cadillac DEVILLE CONCOURS
    Jul 2008
    1
    Hi everyone.. im new here so just bear with me,but im getting those same codes plus P0101 and P0174..Also has service emissions system and check engine light on..I have a 96 concours with 122000 miles...
  12. #11
    68
    81,723
    Check for vacuum leaks.
  13. #12
    codewize's Avatar
    Apr 2005
    Upstate NY
    49
    6,919
    I may or may not have mentioned that I cancelled my Wed appt that week because the codes were gone and I couldn't make them come back.
    At this point it's very intermittent. Some days I get codes and some days I don't
  14. Remove Advertisements
