Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: 95 deville rough Idle, stalls
Old 07-05-08, 01:16 PM
dave3999 dave3999 is offline
Cadillac(s): Cadillac
View dave3999's Photo Album
Casino Cash: $335
I have a 95 Deville, 4.9 with a rough idle and stalling problem. Fuel pressure tests fine, vacume can be low (tested as high as 18 and steady, as low as 12 and steady. Current Codes are P053 and p012, sometimes history, sometimes current. Sounds like timing is off (knocks under a load), gettinf ISC code as well on and off. Have been through 3 ISC motors, replaced Hall effect swithc, ECM and PCM. New cap, rotor and coil (old looked awful). Sprayed starting fluid around intake, no noticable increase in RPM, Problem is much worse when warm. I'm thinking pick up coil, any suggestions?
  #2 (permalink)
Old 07-05-08, 02:08 PM
Casino Cash: $335
Re: 95 deville rough Idle, stalls
Just drove the car again, now code PO23 current and others history.
  #3 (permalink)
Old 07-05-08, 02:56 PM
submariner409's Avatar
submariner409 submariner409 is offline
Cadillac(s): 2002 Cadillac F55 STS/51000mi., 2004 Ford F150 Super cab 4x4
Casino Cash: $16874
Vacuum seems low, especially if idle is only 18".
  #4 (permalink)
Old 07-05-08, 04:51 PM
Casino Cash: $335
Could the vacume be causing the ignition codes? I cant seem to find a leak. Could an ignition broblem cause the vacume problem?
  #5 (permalink)
Old 07-05-08, 05:04 PM
Casino Cash: $16874
Not sure about your particular ignition system, but a retarded spark at idle will sometimes cause a decrease in vacuum as well as a low-speed miss.
  #6 (permalink)
Lithorian's Avatar
Lithorian Lithorian is offline
Cadillac Owners Enthusiast
Cadillac(s): 1995 Deville 4.9 Liter, 1988 Camaro Iroc-Z 5.0 Liter
View Lithorian's Photo Album
Casino Cash: $4670
my 95 deville pulls 22 in vacum at idle, i would start with your distributor seeing as you have p012 - no distributor signal and p053 - distributor signal interupt, change the pick up coil, search for a vacuum hose at the back of the motor near the driver's side corner, that damn hose ALWASY gets knocked off while doing the rear plugs, that will cause your low vacuum and is hard to get starting fluid in, as for the ISC you need to calibrate it or it wont work right, with the engine running, lift the throttle off the plunger and push the ISC in till it bottoms out, disconnect the ISC and adjust the plunger so that the gap between it and the throttle is .060, if i am correct, of course ranger will correct me if i am wrong:P, as for the knock under load it's PROBABLY spark knock, try rodding out the two EGR tubes in the throttle body. I had most of these problems with my deville as well, except for the distributor codes, so i have a few more tricks up my sleeve if this doesnt work. p023 - EST signal problem
  #7 (permalink)
Old 07-22-08, 11:10 PM
Casino Cash: $335
took it to the shop to have pick up coil replaced, put in new distributor and harness (wires were falling apart). No change, runs great cold, huge miss when warm. Mechanic is scratching his head. Fuel pressure fine according to him, he thinks vacume is also good.
  #8 (permalink)
Old 07-23-08, 01:37 AM
Lithorian's Avatar
Casino Cash: $4670
..... any other codes? i'd almost think that its would be a PCM problem...
  #9 (permalink)
Old 07-23-08, 02:42 AM
ogbuehi ogbuehi is offline
View ogbuehi's Photo Album
Casino Cash: $435
Try cleaning out the EGR tubes. That always works for me.
  #10 (permalink)
Old 07-25-08, 04:40 PM
Casino Cash: $335
Car has been in the shop for 3 weeks, mechanic replaced dist & pick up coil, I cleaned out egr before taking it in. I replaced PCM before I took it in (problem with Idle speed motor went away), Mechanic says no codes now, fuel pressure and vacume test good. He is convinced it is an ignition problem but cant find it. Refering to dealer. Any ideas?
deville, idle, rough, stalls
detail pro cadillac whitewall wipes
cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum | Sirius Radio
