Cadillac DeVille 1985 to 2005 including: 1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille, 1985-1992 Fleetwood and 1993 Sixty Special. | Cadillac Forums: Car pulls to the right...read inside
05-14-08, 07:05 PM
|  | Cadillac Owners Fanatic Cadillac(s): 1998 Cadillac DeVille | | Join Date: Jan 2008 Location: Ca | | | Car pulls to the right...read inside Hey guys, my car has always been pulling to the right, and today I went and got an alignment done, and yeah it was a bit messed up, but even after alignment was done, my car tends to pull to the right when I let my hands off the steering wheel. Even on a straight road, it will do the same. Any idea on what could be the problem? Got even thread tires, even amount of PSI. |
05-14-08, 07:41 PM
|  | Cadillac Owners Fanatic Cadillac(s): White Diamond '03 DTS | | Join Date: Feb 2007 Location: Elgin, IL | | | Re: Car pulls to the right...read inside Try swapping the front tires side to side and see if that makes any difference. |
05-14-08, 08:29 PM
| | Cadillac Owners Connoisseur Cadillac(s): 1988 Allante' (sold), 1984 Eldorado 4100 91 Allante | | Join Date: Feb 2003 Location: california Age: 62 | | | Re: Car pulls to the right...read inside I agree. Assuming alignment done correctly, the front tires have taken a set. I take the right rear tire and put it on the right front when that occurs. I'm surprised the shop didn't do that when they road tested it after, then took your money? |
05-14-08, 08:57 PM
|  | Cadillac Owners Fanatic Cadillac(s): 1998 Cadillac DeVille | | Join Date: Jan 2008 Location: Ca | | | Re: Car pulls to the right...read inside They have tried that before, thats the first thing they have done like a week ago!
Maybe my left side spring tension is different from right spring...that will cause it to do that...no? |
05-14-08, 10:07 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 96DeVille | | Join Date: Aug 2005 Location: NY Capitol District Age: 62 | | | Re: Car pulls to the right...read inside Road crown will take a vehicle to the right. Is the steering wheel centered? If alignment is to the numbers it should track straight on a dead level surface. Braking hands off will also tell the tale. K_C |
05-15-08, 04:22 AM
|  | Cadillac Owners Fanatic Cadillac(s): 1998 Cadillac DeVille | | Join Date: Jan 2008 Location: Ca | | | Re: Car pulls to the right...read inside Quote:
Originally Posted by krimson_cardnal Road crown will take a vehicle to the right. Is the steering wheel centered? If alignment is to the numbers it should track straight on a dead level surface. Braking hands off will also tell the tale. K_C | I believe the steering wheel is straight. Whenever I brake without hands steering wheels turn to the right and car pulls to the right. Not cool.
How would I go about re-seating the steering wheel? Because I have to keep the steering wheel a little bit to the left for wheels to be straight. So, would the steering wheel be the problem? |
05-15-08, 07:25 AM
| | N* Headgasket Survivor Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold) | | Join Date: Apr 2007 Location: The Ocean State Age: 46 | | | Re: Car pulls to the right...read inside Dragging RF brake caliper? Check to see if pad wear is even side-to-side. |
05-15-08, 09:48 AM
|  | Cadillac Owners Enthusiast Cadillac(s): 96DeVille | | Join Date: Aug 2005 Location: NY Capitol District Age: 62 | | | Re: Car pulls to the right...read inside Only way to center the steering wheel is during a front end alignment thru the tie rod adjustment I believe. It needs to be centered when positioning the car on the racks before the alignment work is done. If you've recently had the work done go back and explain the situation to the tech [which way it tracks], they understand the importance of getting it right. When you drive a straight stretch of road w/ the wheel centered the car should track straight. Braking will exaggerate the pull. K_C |
05-15-08, 11:04 AM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Car pulls to the right...read inside Yeah, it's not the steering wheel. The off-center steering wheel is caused by whatever is making the car pull right: alignment, dragging brake pads.......When you mentioned that the car pulls right on brake application points to brake problems. |
05-15-08, 05:19 PM
Originally Posted by chubbyranger Dragging RF brake caliper? Check to see if pad wear is even side-to-side. | Will do boss! As soon as moms done with the car. |
05-15-08, 05:21 PM
|  | Cadillac Owners Fanatic Cadillac(s): 1998 Cadillac DeVille | | Join Date: Jan 2008 Location: Ca | | | Re: Car pulls to the right...read inside Thanks guys, I will release the caliper pistons and re-seat the pads and see if it helps. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
