cadillac parts
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Register FAQ Donate Calendar Mark All Cadillac Forums Read
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: A/C problem
  #11 (permalink)
Old 05-10-08, 01:23 PM
donwon donwon is offline
Cadillac(s): 89 Seville 92 Deville
Casino Cash: $1835
Re: A/C problem
Open the door on the glove box and take the screws out and pull the box out
and you can see the actuator and if it is moving or not.
I think 3 screws( maybe just 2) hold the control and actuator in place
so it won't be hard to take it off and see if it will operate
when not connected to the temp control door.
  #12 (permalink)
Old 06-01-08, 11:10 AM
zentrade zentrade is offline
Cadillac(s): Cadillac 1993 Deville 4.9
Casino Cash: $1912
Re: A/C problem
Thanks! Just getting around to checking this problem out today and was going to ask if going through glove box the best way to check it out....Thanks for the help!
  #13 (permalink)
Old 06-01-08, 01:03 PM
Casino Cash: $1912
Re: A/C problem
ok..took glove box out and ran the car and ran the temperature buttons up and down between 60 and 90 degrees and did not see the blend door arm move at all. Heard the compressor kick in and off and the blower kick in and off while pressing the warmer and cooler buttons through the range.
Quick way to test the actuator if i remove it out of the car?
  #14 (permalink)
Old 06-01-08, 03:25 PM
carnut carnut is offline
Cadillac(s): 1988 Allante' (sold), 1984 Eldorado 4100 91 Allante
Casino Cash: $3035
Re: A/C problem
Remove the threaded rod from the programmer and verify the blend door itself is not stuck. Move the rod back and forth, sometimes when its snapped onto the rod, its too far one way or the other and will cause the blend door to stick. If the white plastic rod retainer on the programmer moves smoothly with the rod disconnected from 60 to 90 degrees then the arm was misadjusted. If it still does not move the stepper motor within the programmer is toast.
  #15 (permalink)
Old 06-01-08, 03:49 PM
Casino Cash: $1912
Re: A/C problem
ok thanks!
  #16 (permalink)
Old 06-03-08, 03:30 PM
Casino Cash: $1912
Re: A/C problem
I unsnapped the arm (metal threaded rod) and found the blend door to move freely with no problems. I forgot to check if the arm itself moves freely throughout temp. range while disconnected from the door. I did however find a little blue wire disconnected from the box (which i assume is the control motor) for the arm. Maybe thats the problem? Just trying to see how i can get the motor box out to reattach wire (cant do so in dash) and see if thats the problem. Will update or wait for any help if anyone knows?. Thanks again!
  #17 (permalink)
Old 06-04-08, 11:50 AM
Casino Cash: $3035
Re: A/C problem
The programmer comes out simply by removing 3, I think, small screws, then its wiggled around to come out from below. Thats assuming the lower dash cover is removed. Before trying to remove it, verify the arm moves with rod off.
  #18 (permalink)
Old 06-04-08, 03:04 PM
Casino Cash: $1912
Re: A/C problem
ok thanks!, will take me a couple days to do that and will update
Tags:
vB code is On
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
earn
vacation travel
golf store
silver, gold, diamonds
Powered by vBulletin® Version 3.6.10
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
