| Re: Low oil light ~ 98 DeVille Northstar You can change the sending unit with one proper sized wrench, a rag, and some magic words. Easier if the car is up in the air. No different from unscrewing a spark plug and replacing it. It's the thingy with a wire sticking out right above the oil filter.....probably easier if the filter is off, so wait until you do an oil change, or have it done at your local Mom & Pop garage. It's not rocket science.
Low oil level: Amount of oil in the oil pan
Low oil pressure: Same as blood pressure. |
