Cadillac DeVille 1985 to 2005 including: 1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille, 1985-1992 Fleetwood and 1993 Sixty Special. | Cadillac Forums: In the Deville search....
04-27-08, 12:44 AM
|  | Cadillac Owners Master Cadillac(s): 94 Fleetwood Brougham | | Join Date: Aug 2004 Location: Rockford, IL Age: 42 | | | In the Deville search.... Any thoughts on this one? http://www.cars.com/go/search/detail...eadExists=true
Good? Bad? Warning signs?
Things to look for that are "must haves"? |
04-27-08, 10:09 AM
|  | Auto Enthusiast Cadillac(s): NONE | | Join Date: Jul 2005 Location: Downers Grove,IL Age: 29 | | | Re: In the Deville search.... Check out the suspension thoroughly. The struts are $$
Make sure the 100K service was done, that is $$
Check for coolant smell. The waterpump replacement is not a walk in the park on that motor.
My brother got 120K out of his last DTS before he decided to stop sinking money into it. Mainly the suspension work and crank shaft position sensors were what cost him the most.
__________________ 1996 Cadillac Fleetwood Brougham "SS"- sold but not forgotten 1998 Lincoln Mark VIII- the daily driver 2002 Trans AM WS6 CE Convertible- the show car 2003 Infiniti M45-wifes daily driver |
04-27-08, 10:54 AM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac | | | | | Re: In the Deville search.... The only thing I'd say you shouldn't get in an older car (one over 5 years old) is the moonroof. It's a useless option that causes very expensive problems. Also, that's kinda high mileage for an '02. (Most sources state "average" mileage as 12,000-15,000 per year.) Not that high mileage is a bad thing, but that the mostly "trouble-free" period is long gone. Big repairs aside, it could still dollar you to death with little things that pop up after 5-6 years (belts, hoses, gaskets, battery, rotors, alternator, water pump, etc..) Caddies are nice cars, but can be expensive to maintain.
Reason: spelling
04-27-08, 12:39 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: In the Deville search.... I am always Leary of buying a high mileage car from a non dealer used car lot. It most certainly came through the auction. That may or may not be a bad thing, but I'd check it out real closely. Just my suspicious nature. |
04-27-08, 02:24 PM
|  | Cadillac Owners Master Cadillac(s): 94 Fleetwood Brougham | | Join Date: Aug 2004 Location: Rockford, IL Age: 42 | | | Re: In the Deville search.... Maintenance/repairs are a reason I am seriously trying to weight it out, as I don't wanna get into a maint headache car that I need to depend on for another 100-150K, or more....
My FW needs front suspension rebuild (Ball Joints, and arm bushings, the rest is newer except the damper), tires (I DO wanna go Impala SS wheels....) rust fixing (unk $?), get my 3.42's back in there with the FW axle and my posi diff, exhaust, engine back if I can pull it (headers and 2.5" pipe with some Walker Dynomax 17749's), Maybe a HD2 TransGo Kit, and some other smaller things.
The biggest goal more than any is higher mpg, which is why I almost might go with the 3800 SC Ultra over the Cad (but the Cad's do have good prices, $/goodies... but if they are a headache, not worth it...) And the 3800's are a tough engine for longevity. And this one seems pretty well taken care of and garaged its whole life. |
04-27-08, 04:33 PM
|  | Cadillac Owners Master Cadillac(s): 94 Fleetwood Brougham | | Join Date: Aug 2004 Location: Rockford, IL Age: 42 | | | Re: In the Deville search.... Yup, it says it has the electronic struts. The PA/LeSabre are on the Seville/Deville 1994-up "K" chassis. So they share all those cars have, as do the Aurora/Bonneville. The chassis was first on Cadillac in the 1994 Devilles, and in 1998 Buick picked it up and in 2000 Pontiac picked it up.
Autozone lists only the non-electronic for $75 each. Unless they are electronic. It didn't bouncy ride, it seemed fine, but seemed almost twitchy in the steering. Wasn't sure it was just weak bars. They might have been find. It is probably more kin to the soft "dynaride" Buick owners seem to like. I guess I can opt for Bonneville SSEI springs to beef things up a bit. Rear springs are pretty each to change, front, not too bad, but need to get some air tools to get the strut apart as well as a spring compressor.
04-27-08, 08:55 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: In the Deville search.... Keep in mind that the S/C 3800's require premium. Naturally aspirated 3800's don't. |
04-27-08, 10:04 PM
|  | Auto Enthusiast Cadillac(s): NONE | | Join Date: Jul 2005 Location: Downers Grove,IL Age: 29 | | | Re: In the Deville search.... Quote:
Originally Posted by Ranger Keep in mind that the S/C 3800's require premium. Naturally aspirated 3800's don't. | I mentioned that to him. The normally aspirated 3800s make relatively good gas mileage, but the S/C loses a few mpg in the city and highway. |
04-27-08, 11:09 PM
|  | Cadillac Owners Master Cadillac(s): 94 Fleetwood Brougham | | Join Date: Aug 2004 Location: Rockford, IL Age: 42 | | | Re: In the Deville search.... I can also tune the 3800 and remove that requirement... I can also make it run on E85 (if the fuel system supports it). Which is $2.699 a gallon and 105 octane, which a boosted 3800 would go bonkers over...
Get me some 45-60 lb injectors (have to do the math) and run it on the alky....
If I get a Deville, i will do the same to it for sure.... Just need to find injectors that work in there that are fat....
04-29-08, 01:00 PM
| | Cadillac Owners Enthusiast Cadillac(s): 93 Sedan Deville 4.9L | | Join Date: Sep 2005 Location: Texas | | | Re: In the Deville search.... Quote:
Originally Posted by N0DIH I can also tune the 3800 and remove that requirement... I can also make it run on E85 (if the fuel system supports it). Which is $2.699 a gallon and 105 octane, which a boosted 3800 would go bonkers over...
If I get a Deville, i will do the same to it for sure.... Just need to find injectors that work in there that are fat.... | I knew you lost a few MPG running your FWB on E85, Did you ever get it tuned to make it get the same gas mileage as regular unleaded?
Unfortunately we dont have any E85 here else i might consider trying to set mine up. |
04-29-08, 09:34 PM
|  | Cadillac Owners Master Cadillac(s): 94 Fleetwood Brougham | | Join Date: Aug 2004 Location: Rockford, IL Age: 42 | | | Re: In the Deville search.... No, but I got within 2-3 pretty consistently. My average is 18.5 to 19.5 for ALL tanks of gas sans the sub zero months, else they all seem to end up in there. And E85 I am at the 15.3 to 17.7 for ALL tanks of E85. So really, I am not doing too badly. And note that my FW is stone stock with LS6 injectors (which flow identical to stock, they are there because I was told they were larger, the are not, so I didn't wanna go in and remove them....) They will probably end up in my 454 Suburban soon enough....  | | Cadillac Discussion Tools | | |
Censor is ON | | | |
