Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: Heavy vibration when braking. Warped rotors?
Old 04-22-08, 06:26 PM
Cadillac(s): 1997 Deville Base, 1992 Buick Roadmaster Limited
View raoul742024's Photo Album
Casino Cash: $1480
Since i went to get new tires for the Lac teh front end vibrates badly when braking from 50 mph and up, not so bad under 50. I checked the pads and they still look fairly new. I don't have the time right now to have them machinced. Just wondering if they is anything else i should be looking for.
  #2 (permalink)
Old 04-22-08, 06:55 PM
krimson_cardnal's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 96DeVille
View krimson_cardnal's Photo Album
Casino Cash: $4246
Re: Heavy vibration when braking. Warped rotors?
If they hammered the wheels on with their pneumatic wrenches it's possible the rotors are now warped. Crack the lugs and re-tighten by hand, might not be that bad and a quick release coud do it. K_C
  #3 (permalink)
Old 04-22-08, 07:17 PM
View Ranger's Photo Album
Casino Cash: $24191
My guess is uneven brake pad deposits. Resurface them, after following KC's advice.
  #4 (permalink)
Old 04-23-08, 09:00 AM
Cadillac(s): Cadillac
View rich2000's Photo Album
Casino Cash: $370
I WOULD NOT resurface them. Rotors today are too thin to resurface. What will happen is, after they get hot they will warp all over again. Buy new ones for only about $25.00 each. Not worth the trouble.
  #5 (permalink)
Old 04-23-08, 10:36 AM
Casino Cash: $24191
A very light skim cut should not hurt anything. I've had many rotors resurfaced and have yet to have a problem.
  #6 (permalink)
Old 04-23-08, 11:03 AM
Casino Cash: $4246
They call it truing. As long as it's within spec no problem. New out of the box rotors can need turning. Not that they are warped, just not true. K_C
  #7 (permalink)
Old 04-25-08, 03:50 PM
Casino Cash: $1480
Thanks for the help everyone. The rotors still look like they can be turned but i don't have a micrometer to check. I'll retighten the legs and see if it helps. Rich2000 where are you getting rotor for $25.00? Everywhere around me they average about $80 a piece. Just like Ranger I've have many rotors resurfaced with no problems.
  #8 (permalink)
Old 04-25-08, 06:43 PM
Cadillac(s): 1996 sedan deville 1997 deville
View figment3's Photo Album
Casino Cash: $645
i live in toronto, and had the same problem as you, changed all four rotors,and now smooth as silk, front ones where $30 each and back where $25, took me less than an hour to do all four,not worth turning
  #9 (permalink)
Old 04-25-08, 07:13 PM
Casino Cash: $4246
Value of the dollar, eh? Figure $75 - $85 each rear, fronts twice that - OEM. Cheap ones less - but then again.... Pull the wheels, be sure the rotors are seated cleanly, put it back together and see how it is. If needed have 'em trued. K_C
  #10 (permalink)
Old 04-25-08, 10:54 PM
Casino Cash: $24191
I seem to recall Napa turning my rotors for $15 ea. I also seem to recall them having new ones for about $20.
  #11 (permalink)
Old 04-29-08, 04:40 PM
BigDaddy63's Avatar
Cadillac(s): 2002 Cadillac Deville DTS
View BigDaddy63's Photo Album
Casino Cash: $680
I just did the brakes on my wife's car. Pep Boys turned the rotors for $10 a piece. As long as the rotors have enough meat on them, they will be fine. Never put old pads on new/turned rotors.
Sometime if the pads wear uneven or if you drive through puddles after the rotors are hot, they can warp. If you have a mircrometer you can test them for run out. Make sure the guy cutting the rotors knows what he's doing. If they are cut to aggressively or not properly, they will be worse than now.
  #12 (permalink)
Old 04-29-08, 04:57 PM
tateos's Avatar
Cadillac(s): 1997 ETC, 2000 DTS
View tateos's Photo Album
Casino Cash: $8309
I read something recently that said what Ranger said - that pulsation is almost never caused by warpage - it is usually uneven deposits of brake pad material on the rotor cheeks. I am not saying it is true, but I did read it; if so, maybe just scuffing up the rotor cheeks by hand will help...???
  #13 (permalink)
Old 04-29-08, 05:06 PM
View cadillacroadside's Photo Album
Casino Cash: $2025
if it is the brake rotors causing your concern, when you do straighten out the rotor problem make sure your wheels lugs are toqued properly, there were tsb's from gm concerning the overtightening of wheels causing brake rotor pulsations
  #14 (permalink)
Old 04-29-08, 07:30 PM
Casino Cash: $24191
Tateos, I tried scuffing them up by hand on my daughters first car when she was going to sell it. No joy. I had to have them trued on a brake lathe to cure it.
This may be what you read.
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Tags: , , , ,
braking, heavy, rotors, vibration, warped
