Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: Adding DTS foglights into a DHS
Old 04-19-08, 02:34 PM
Cadillac(s): '01 Blk/Blk Deville DHS
View risho's Photo Album
Casino Cash: $9000
I plan on adding the DTS foglights to my DHS by next month, so far I ordered a DTS bumper cover and 2 DTS foglights, now I cant seem to find just the foglight switch alone, all I can find is the whole panel with headlight/auto light and foglight switches, do I need to buy a whole new switch panel to use the factory DTS switch? Or can I get a foglight switch from a DTS in the junkyard and modify it to work in my DHS?
  #2 (permalink)
Old 04-19-08, 03:10 PM
submariner409's Avatar
Casino Cash: $20719
Re: Adding DTS foglights into a DHS
Whole switch because the fog lights are controlled on and off not only by the pushbutton but also by different headlight settings.
  #3 (permalink)
Old 04-19-08, 03:39 PM
Casino Cash: $9000
So would that mean when I would go to use my highbeams my foglights would shut off? If so is there some sort of mod that wold keep them on, I recently did the "quad" beam mod to keep lo/hi beams on at the same time.
And I plan on using a bosch relay setup for the main power on the foglights as far as the switch itself would I be able to run just a positive to the new dts switch panel in my interior to control the foglights?
  #4 (permalink)
Old 04-19-08, 05:27 PM
Casino Cash: $20719
Federal and state illegal. Sure ticket from State Smokey. That's exactly why the switching system is built that way. Besides, fog lights put a diffuse beam down low and on the road less than 25 feet in front of the car and the lens and reflectors are specifically designed to work that way. Other than looking sort of ricer, there's no practical reason to light all 4 in high.
If you want to go really wildly illegal, substitute a set of 1,000,000 candlepower Hella or PIAA driving lights for the fogs and aim them parallel to the road.
  #5 (permalink)
Old 04-19-08, 07:24 PM
Logandiagnostic's Avatar
Cadillac Owners Enthusiast
View Logandiagnostic's Photo Album
Casino Cash: $2755
When I created my fake DTS....
I simply spliced the foglamps with the headlamp low beams. So anytime the car is in gear, both low headlights and foglamps are on.
Foglamps turn off on high beam.
It should be noted, you will not find any plugs in the harness for the foglamps. In other words, there are no hidden connectors taped to the harness.
Logan Diagnostic LLC
www.ledfix.com
www.airbagcrash.com
www.logandieselusa.com
  #6 (permalink)
Old 04-22-08, 12:49 PM
Cadillac(s): Parents own Devilles '98, '02
View BAMSTS's Photo Album
Casino Cash: $460
How much do you estimate this whole project will cost, if you don't mind me asking?
  #7 (permalink)
Old 04-24-08, 09:33 PM
Cadillac(s): Cadillac
View MisterBlue's Photo Album
Casino Cash: $2139
IMHO, it's really not worth the expense and effort. If you have really good low beams, the added light from the fog lights is barely noticeable when it's not foggy. And when it is foggy, good low beams throw glare over top of the fog lights' beam, so they're no good then, either! I had 'em in my Lincoln, my STS, my Mustangs, My Z-28, and my Dodge truck, but I'd never pay extra for them.
Anyhow, fog lights work best when they're yellow or amber, and you can turn off the regular headlights. That's illegal - fog lights are classified as "auxiulliary lighting", and youi can't drive with just aux lights. That's also why the factory switching won't allow you to have just the fog lights on. Stupid law, admittedly, but it was enacted because most all factory fog lights have no provisions for aiming them.
  #8 (permalink)
Old 04-24-08, 10:31 PM
Casino Cash: $9000
I plan on doing it just for the "look" same reason people drop thousands on big shiney rims, thats next on my list , it wasn't much at all for what you end up getting, my total so far is about $650, thats including GM bumper cover/GM foglights/3000k(yellow) HIDs/GM DTS switch, plus paint work which my buddy at the body shop should help make a lil cheaper.
Tags: , , , ,
adding, dhs, dts, foglights
