Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: A metallic jingle while turning
Old 04-08-08, 08:42 AM
geigs's Avatar
Cadillac(s): 1994 Cadillac Sedan DeVille
View geigs's Photo Album
Casino Cash: $550
Question A metallic jingle while turning
Hi all,
Just recently, I noticed a metallic jingling noise coming from the front driver’s side wheel when making a left hand turn or veering left. (1994 Cadillac Sedan DeVille, 4.9 with 72,xxxx miles) It does not seem to matter the speed, but seems more pronounced at faster speeds. The reason I describe it as a jingle is because it sounds like loose change ($) that has been amplified and it's high-pitched. I first noticed it last Friday during a rain storm. I checked the power steering fluid last night and it was a little low, but not severely, so I added some Lucas Power Steering Stop Leak. This morning (after an eight mile drive) I smelled the wheels (hey, you never know) and the passenger front side wheel seem to have a slight burning odor, but nothing a person would notice unless he put his nose up to it. Any suggestions on what this may be and if it warrants concern would be greatly appreciated. Thanks!
  #2 (permalink)
Old 04-08-08, 05:51 PM
submariner409's Avatar
Casino Cash: $20719
Re: A metallic jingle while turning
Have the brake pads been changed, ever ? Not sure about your year, but the pads should have spring steel fingers which rub on the rotor as the pad lining gets dangerously thin. The noise can be pretty loud. Power steering has nothing to do with brake heat or smell.........
Also, check the rubber boots over the constant velocity joints....if one has cracked and the grease gone dry there can be all sorts of metallic mayhem going on just inside the wheel hub area, between the hub and transmission.
  #3 (permalink)
Old 04-08-08, 08:46 PM
Cadillac(s): 89 Seville 92 Deville
View donwon's Photo Album
Casino Cash: $2410
If you have to put new pads on it, it is a good time to change the rubber break lines.
  #4 (permalink)
Old 04-08-08, 09:44 PM
ewill3rd's Avatar
Cadillac Technician
Cadillac(s): none
View ewill3rd's Photo Album
Casino Cash: $16967
You sure it is a left turn?
Sometimes on hard right turns if the starter is bad the bendix will slide out and jingle on the flywheel.
Have seen that a few times.
Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group.
  #5 (permalink)
Old 04-09-08, 01:06 PM
krimson_cardnal's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 96DeVille
View krimson_cardnal's Photo Album
Casino Cash: $4246
It's all that spare change Cadillac owners have laying around in their rides after spending all the paper stuff! Smell might be coming off engine - bit of oil on a hot part could do that. Brakes/hub/CV make sense as source to me.
Would never have guessed at ewill3rd's observation. Makes sense though, might not be odds on favorite, but it does point out it can come from any where. With all that spare change rattling around us owners need to think out of the box. K_C
  #6 (permalink)
Old 04-11-08, 11:32 AM
geigs's Avatar
Casino Cash: $550
And the answer is: left, front brake caliper is frozen and while there is plenty of pad life on right front, there is almost none on the left. It was also noted that the rotors are rusty (which I noticed as well), so I'm replacing both calipers, and putting new rotors and pads on. Of course they recommended flushing the ps,trans, and fuel system, but I passed on that for today. Thanks for all your suggestions!
  #7 (permalink)
Old 04-11-08, 11:44 AM
Casino Cash: $4246
Sure you need to replace calipers? With a disassembly they certainly can be cleaned up to be serviceable. A common cause to a frozen caliper are the slide and pins. Lots of time they aren't properly lubed. K_C
  #8 (permalink)
Old 04-21-08, 03:21 PM
geigs's Avatar
Casino Cash: $550
KC, I would not doubt your assessment. I just was on a business trip and on the way to the airport, the limo driver was telling me about a mechanic in my area who services his limos and usually the mechanic can make the old stuff serviceable rather than replacing it.
  #9 (permalink)
Old 04-21-08, 03:45 PM
Casino Cash: $4246
Thanks geigs, so what was your solution? Is everything rolling smooth and is there spare change in your pocket - not clanging around in the wheels and brakes??? As long as you're satisfied with how it worked out then life is good. K_C
  #10 (permalink)
Old 05-02-08, 12:38 PM
geigs's Avatar
Casino Cash: $550
My solution was just to replace everything. The way I look at it is that if your car does not stop when it's supposed to, you might not get a second chance. As for spare change in my pocket; I'm not concerned, I'm sure the government will bail me out.
Tags: , , , ,
jingle, metallic, turning
