Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: 1992 sedan deville won't start...
Old 03-31-08, 08:11 PM
Cadillac(s): 1988 Sedan Deville, 1992 sedan deville
View HotrodMamma's Photo Album
Casino Cash: $345
Hi group! I have a 1992 Sedan Deville that won't start...acts like it wants to. Sometmes does start but shuts off at warm up. The oil is black as pitch..(last owner). Would that cause it? I read the threat on the resistor contacts on the keys. I could check that too if it's a possibilty....Thanks!
  #2 (permalink)
Old 03-31-08, 09:52 PM
Cadillac(s): 1996 Deville (sold), 2000 Mustang GT
View misfit6794's Photo Album
Casino Cash: $9379
Re: 1992 sedan deville won't start...
There are a ton of things that can prevent the car from starting. Heres a list, in the order you should check; Battery, battery cables/terminals, starter, starter solenoid, fuel filter, spark plugs, plug wires, distributor, fuel pressure regulator.
I'm going to guess its the starter, usually they will affect hot starts, I am not positive where it is on your model, its usually on the bottom of the engine bay. Try giving it a couple hits with a hammer, if it starts after that, then its definetly bad.
  #3 (permalink)
Old 03-31-08, 10:05 PM
BigDaddy63's Avatar
Cadillac(s): 2002 Cadillac Deville DTS
View BigDaddy63's Photo Album
Casino Cash: $680
From your description, it sounds as if the car has not been maintained properly. Check/ replace all fluids- oil, tranny, antifreeze- filters, plugs, cap, rotor, wires, pcv valve, etc. I would do a thorough cleaning of the TB and intake manifold of carbon. I would also do a Seafoam or similar treatment for the oil and gas.I doubt it's the starter as you said the car will run but shuts off.
  #4 (permalink)
Old 04-01-08, 01:15 AM
Lithorian's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 1995 Deville 4.9 Liter, 1988 Camaro Iroc-Z 5.0 Liter
View Lithorian's Photo Album
Casino Cash: $4730
one other item, that cause me the EXACT same symptoms, the Idle Speed Controll motor
  #5 (permalink)
Old 04-01-08, 12:49 PM
Cadillac(s): 89 Seville 92 Deville
View donwon's Photo Album
Casino Cash: $2385
Put a fuel pressure gauge on the fuel rail, the pump may be failing.
Also check the fuel pressure regulator.
  #6 (permalink)
Old 04-01-08, 01:13 PM
Casino Cash: $345
Thanks guys. I'm buying the car today, just wanted to know what I should check for this weekend if replacing the fluids and such failed. I do have some seafoam on hand as well. I'll let you know what we find.
  #7 (permalink)
Old 04-08-08, 02:47 PM
Casino Cash: $345
It sounds like the fuel pump. I say "sounds" because it makes a grinding noise when the power is on. We will do a pressure test this weekend to be sure. Another question that this group probably knows the answer to: is there and access panel to the fuel pump on this model or do we need to drop the tank? '92 Sedan Deville...thanks group!
  #8 (permalink)
Old 04-08-08, 07:29 PM
N* Headgasket Survivor
Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold)
View chubbyranger's Photo Album
Casino Cash: $2175
Must
d
r
o
p
tank...
  #9 (permalink)
Old 04-08-08, 08:29 PM
Casino Cash: $2385
It ain't hard to do.
  #10 (permalink)
Old 04-22-08, 04:34 PM
Casino Cash: $345
Talking Re: 1992 sedan deville won't start...
Well, gang...you're going to laugh...after all that fuss, the Caddy was OUT OF GAS!!! The tank showed it had 5 gallons, but someone had run it over a big rock or something and the tank was dented. It threw the fuel sensor off. After putting some gas in it, the pressure gauge started showing pressure and then it started...LOL! It still has running problems, however. At first it sounded like it was not sparking on a plug. When I checked plug 1 wire was not attached. I attached it..it ran better but still is running rough and throwing a lot of carbon out of the tail pipe. So this morning I changed plug 1. The prior owner had removed it and dropped it. I replaced it but still runs rough with carbon out of the exhaust. Would a damaged plug wire do that? I am planning on a tune up this weekend. Thanks gang.
  #11 (permalink)
Old 04-22-08, 07:08 PM
View Ranger's Photo Album
Casino Cash: $24216
Check the FPR.
  #12 (permalink)
Old 04-22-08, 09:40 PM
Cadillac(s): 93 Sedan Deville 4.9L
View behind-bars's Photo Album
Casino Cash: $14006
I would just replace alot of regular maintenance parts before going to deep.
Replace all fluids, cap, rotor, plugs, wires, 02 sensor, and then clean the egr tubes and TB and see how much it cleans up.
  #13 (permalink)
Old 04-22-08, 11:10 PM
Casino Cash: $2175
Change the other 7 plugs. If they are fouled or shot that would be the first step I'd take. Plug wires can also be a problem if they are worn and arcing - then the electricity is going into the block and not the combustion chamber to burn fuel.
  #14 (permalink)
Old 04-22-08, 11:19 PM
CadiJeff's Avatar
Cadillac(s): 1981 CoupeDeville, 2 1990 Eldorados, 1994ETC ,1992STS
View CadiJeff's Photo Album
Casino Cash: $435
hey I was gonn say that...LOL
  #15 (permalink)
Old 04-23-08, 01:50 PM
Casino Cash: $345
Wink Re: 1992 sedan deville won't start...
Thanks fellas. I will do the major tune up this weekend and let you know. P.S...I paid $650.00 for this car because it was out of gas..I guess anything else I do is icing on the cake at this point. I will never tell that young fella what was wrong with the car if I see him again....LOL. The car needed to be with a Cadillac lover anyway and it is.
Tags: , , , ,
1992, deville, sedan, start
