Cadillac DeVille 1985 to 2005 including: 1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille, 1985-1992 Fleetwood and 1993 Sixty Special. | Cadillac Forums: Replacing calipers and rotors on 98 Deville, any bolt on upgrades?
03-16-08, 05:41 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | Replacing calipers and rotors on 98 Deville, any bolt on upgrades? I am going to be replacing the front calipers, pads, and rotors on my 98 Deville. I was wondering if there is any bigger or better stuff that I can put on from a newer/higher performace car. I have the single piston calipers up front, and would like to upgrade if I am changing them anyways.
Thanks, Glen |
03-16-08, 06:08 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 96DeVille | | Join Date: Aug 2005 Location: NY Capitol District Age: 62 | | | Re: Replacing calipers and rotors on 98 Deville, any bolt on upgrades? The OEM equipment on your DeVille is all you need. Do a bit of searching around on this and the suspension forum and you'll find most questions answered. I'm not aware of component upgrades that go beyond the choice of rotors and pads. MHO is to avoid slotted rotors and consider ceramic pads. Do search around a bit. K_C |
03-16-08, 06:38 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Replacing calipers and rotors on 98 Deville, any bolt on upgrades? I'm not going to go drilled rotors, but I was more looking for 2 piston calipers, or larger diameter OEM parts. Ceramic pads are a must though. If there isn't anything its no big deal, I just always beleive in upgrading brakes when possible or convienient |
03-16-08, 07:42 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Replacing calipers and rotors on 98 Deville, any bolt on upgrades? Larger diameter OEM parts run into interference with wheels. Look in the Seville and Suspension forums for posts on conversion to Lucerne calipers. |
03-21-08, 09:11 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Replacing calipers and rotors on 98 Deville, any bolt on upgrades? You can increase the quality of your brakes by using HAWK brand pads. I was not happy with my standard brakes either and made the switch, the advertising hype is for once pretty close to reality.
I used the HAWK HPS pads as they are supposed to have more grip than the ceramics. The only other thing you have to watch out for is use extra lube on the caliper bolts or the pads will shimmy. |
03-21-08, 11:32 PM
| | Cadillac Owners Connoisseur Cadillac(s): '05 Dodge RAM Daytona, 96 Dodge B1500 van,'05 Suzuki Forenza | | Join Date: Oct 2003 Location: Florida Age: 38 | | | Re: Replacing calipers and rotors on 98 Deville, any bolt on upgrades? Get one of these it'll upgrade the car, oh wait ya already got one under the hood!.  | | Cadillac Discussion Tools | | |
Censor is ON | | | |
