Transmission Fluid
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Transmission Fluid in Past Cadillac Vehicle Discussion; I have an '86 FWD Fleetwood. The manual says to use Dexron II. transmission fluid, but you can hardly find ...
    hillbillywood's Avatar
    hillbillywood is offline Cadillac Owners Member
    Automobile(s): 1977 Cadillac Fleetwood Limousine
    Feb 2004
    Birch River, West Virginia
    44
    55
    Transmission Fluid
    I have an '86 FWD Fleetwood. The manual says to use Dexron II. transmission fluid, but you can hardly find it. Looks like there's a lot of Dexron III. Is the "III" okay to use? Thanks!
    JeffS_76's Avatar
    JeffS_76 is offline Cadillac Owners Member
    Automobile(s): 1991 Fleetwood
    May 2004
    Mississauga, Ontario, Canada
    40
    13
    Re: Transmission Fluid
    I found this little titbit of info on Dextron III fluid.
    http://www.shel.ca/code/products/com.../pz_header.pdf
    Says its ok to use it on systems requiring Dextron II fluid near the bottom. Hope this helps.
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Use the Dextron 3....it has superceded the older Dex2
    Feb 2004
    44
    55
    Thanks, JeffS. By the way, nice pics of your Sedan deVille.
    Feb 2004
    44
    55
    Quote Originally Posted by bbob
    Thanks to you also, bbob. I KNEW you would give an answer!
  8. Remove Advertisements
