What is pcm memory reset?!?!
Results 1 to 2 of 2
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, What is pcm memory reset?!?! in Past Cadillac Vehicle Discussion; i just tuned up my car and i checked to see if any codes came out n sure nuff there ...
    __CaDiLlAc_PimP__'s Avatar
    __CaDiLlAc_PimP__ is offline Cadillac Owners Member
    May 2004
    Houston,Tx
    33
    i just tuned up my car and i checked to see if any codes came out n sure nuff there was a code called e52 memory reset!?is that a big problem???
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: What is pcm memory reset?!?!
    No, not at all. It happens when the battery is disconnected. Just an "informational" code as the knowlege of a reset when it shouldn't be happening would be valuable to a tech working on a mysterious driveability problem.
