Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: Tires squealing around turns
Old 02-22-08, 02:58 PM
Banned
Cadillac(s): Cadillac
View Roombo's Photo Album
Casino Cash: $950
My 99 Deville has 48k miles and the oem tires. The front ones look new and the rears were good enough for me to pass NJ inspection.
I’m running the recommended 30 all around. The tires are squealing like crazy around turns at slow to moderate speeds, any ideas? Thanks.
  #2 (permalink)
Old 02-22-08, 05:56 PM
submariner409's Avatar
Casino Cash: $20644
Re: Tires squealing around turns
Squealing can be caused by anything from road surface and temperature to tire composition and temperature. Smooth asphalt, polished brick, and some concrete textures squeal like crazy.
About the only thing you have any control over is speed and pressure. Look at the fine print on the sidewall to find out the maximum cold inflation pressure. Probably between 38-41 psi. With the tires cold inflate them to 35 psi using a good dial gauge. See if that helps. (Your ride may get a little harder.)
  #3 (permalink)
Old 02-22-08, 06:00 PM
Cadillac Owners Enthusiast
Cadillac(s): 1985 Sedan DeVille
View ehall's Photo Album
Casino Cash: $10282
Your tires are balding. They may look fine but at 48k you need new ones.
  #4 (permalink)
Old 02-22-08, 06:27 PM
View Ranger's Photo Album
Casino Cash: $24191
It may be out of alignment if the pressures are OK.
  #5 (permalink)
Old 02-22-08, 07:14 PM
Banned
Casino Cash: $950
Thanks for the advice guys
Tags: , , ,
squealing, tires, turns
