Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: 95 Deville Heat Problems
Old 02-13-08, 12:24 AM
Cadillac(s): 1995 Cadillac Sedan Deville
View Bradscaddi's Photo Album
Casino Cash: $335
My Cadillac Takes so long to heat up on the inside, the engine heats up within 4 miles of my house but the inside still isn't warm by the end of my half hour drive to school. My dad suggested a cabin air filter but I don't think it has one. I turn it up to 90 degrees and the fan all the way up, no luck. This is a real bummer with these Michigan winters and no garage. Help? Thanks, Brad
  #2 (permalink)
Old 02-13-08, 12:52 AM
Lithorian's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 1995 Deville 4.9 Liter, 1988 Camaro Iroc-Z 5.0 Liter
View Lithorian's Photo Album
Casino Cash: $4730
Re: 95 Deville Heat Problems
i had the same issue, first look to see if u have any vacuum leaks, all the mixers and air system doors are controlled by vacuum, in order to warm my interior up is to set the system to defog
  #3 (permalink)
Old 02-13-08, 01:27 AM
Casino Cash: $335
Thanks, I will check that out. I already caught your defog trick because there isn't a way to get the heat to come out the vents on the dash, is there?
  #4 (permalink)
Old 02-13-08, 01:39 AM
Lithorian's Avatar
Casino Cash: $4730
no its designed to only come out of the dash and at the floor, AC blows out of the vents, remember its a very large car to warm the interior of too, but usually it gets comfortable in mine within 15 minutes of starting, before i fixed the vacuum leak it would take about 30-45 minutes to get comfortable in, i also have a bad driver side temp mixer or whatever u call it, so cold blows on my side when i use anything except defog, does your cruise control work by chance?
  #5 (permalink)
Old 02-13-08, 01:40 AM
View Ranger's Photo Album
Casino Cash: $24216
No cabin filter on your car.
No way to get heat from the dash vents on your car.
Flush the heater core.
  #6 (permalink)
Old 02-13-08, 02:28 AM
Casino Cash: $335
Yes my Cruise works great. I was kinda hoping I had a cabin filter seemed like it would be an easy fix. I will check out my vacuum tomorrow and the little doors, it could be the vacuum because if I have read right the parking brake release works off vacuum and that doesn't work (my step mom drove a few miles with it on, fried those brake pads). Thanks for the help, Brad
  #7 (permalink)
Old 02-13-08, 03:03 AM
Lithorian's Avatar
Casino Cash: $4730
yea the e-brake releases with a vacuum solenoid, if tit doesnt release u probably have a vacuum leak somewhere, use carb cleaner, spray it around yer vacuum lines, with the motor running and see if u get a reponse from the motor
  #8 (permalink)
Old 02-13-08, 12:08 PM
Casino Cash: $24216
If you have a vacuum leak, the system will default to the defrost mode.
  #9 (permalink)
Old 02-13-08, 05:38 PM
Lithorian's Avatar
Casino Cash: $4730
had a vacuum leak on mine and it came out on the floor
  #10 (permalink)
Old 02-13-08, 05:51 PM
Casino Cash: $24216
That is unusual. Maybe the leak was not bad enough to default.
Tags: , ,
deville, heat, problems
