91 DeVille Hesitation problem (again)
Results 1 to 13 of 13
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 91 DeVille Hesitation problem (again) in Past Cadillac Vehicle Discussion; Just bought a nice 91 DeVille with 60K. Idles a bit rough so I had it checked at a Goodyear ...
    Bill62inphx is offline Cadillac Owners Member
    May 2004
    12
    Just bought a nice 91 DeVille with 60K. Idles a bit rough so I had it checked at a Goodyear dealer. They changed plugs, fuel filter, ran diagnostics, and couldn't find anything. Took it to the mountains and it ran beautifully -- until I was almost home, on freeway, when it started hesitating like it was out of gas -- nearly had to call AAA. Limped on home, put some STP in the tank, and seems OK. Still idles rough and seems to hesitate at times. I tried the WOT test and it accelerated fine. I'm OK with it today, but my confidence isn't high. I don't want this to happen again on the next road trip. Any ideas?
    Ralph's Avatar
    Ralph is offline Cadillac Owners 10000+ Posts
    Automobile(s): Cadillac
    Mar 2003
    Saskatchewan, Canada
    16,105
    Re: 91 DeVille Hesitation problem (again)
    Maybe fuel injectors a little clogged, or worn-out fuel pump? How about the coil? I wouldn't think a clogged cat converter with your mileage. I heard a collapsed (internally) muffler MIGHT cause that but I can't confirm.
    RBraczyk's Avatar
    RBraczyk is offline Cadillac Owners Connoisseur
    Jan 2004
    Amherst, NH
    29
    4,178
    Keep me informed with what happens, I'm kinda in the same boat with my truck.
    Blackout's Avatar
    Blackout is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FTS
    May 2003
    Dover, DE
    33
    4,577
    I have a hesitation problem with my 1990 Deville too every once in awhile. What it does is when you hit the gas it doesn't do anything and then all of sudden it takes off. Its kinda annoying but hey there's a lot of things with the car that are annoying!
    May 2004
    12
    Thanks! I talked to the Goodyear mechanic who serviced it, mentioning injectors, fuel pump, & coil. He said everything on PCM came up normal. He changed plugs without charge due to his own frustration -- no improvement. Car hesitating more than ever. It sure feels like a fuel problem. Can injectors be failing without the PCM detecting this? thanks again.
    RBraczyk's Avatar
    Jan 2004
    Amherst, NH
    29
    4,178
    First Blackout, that may be a throttle problem. Second, bill, Change the fuel filter. It causes a lot of problems.
    90devilleguy's Avatar
    90devilleguy is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 STS-V & 1962 Coupe Deville
    Nov 2003
    Framingham,Ma
    548
    did you have your plugs only changed? if so it may be the sparkplug wires i had a bad wire connection on a set and it caused a hesitation problem every once and a while. put old wires back on and it runs fine now. try that then take it from there.
    May 2004
    12
    Just the plugs were changed. The wires sure don't look new either "ACDELCO Premium Silicon 8mm". Looks like something even I could do this weekend and definitely worth trying before turning it over to a Cadillac dealer$$$. Thanks much.
    May 2004
    12
    Good idea. It was changed a month ago, right before I took this car, which had obviously sat in some old man's garage for awhile, on an unplanned back-road adventure no doubt shaking up the tank and everything else. Could easily have clogged again. Thanks much!
    Murray MacKenzie is offline Cadillac Owners Member
    May 2004
    Quote Originally Posted by Bill62inphx
    Just cured identical problem. Cam position sensor faulty. Error code 41
    Murray
    May 2004
    Just cured identical problem. Cam position sensor faulty. Error code 41.Located in/near distributor. Murray
    ChiMick's Avatar
    ChiMick is offline Cadillac Owners Fanatic
    Jan 2004
    Windy Chicago
    63
    204
    I had the problem where I would press the gas at a stoplight and for a fraction of a second nothing would happen- the natural instinct is to press down MORE on the throttle and then it would take off like a dragster!
    I sprayed all of the throttle linkage and anything that looked like it might move in the area of the throttle body with tri-flow lubricant just before going off on a trip this weekend and the car seems to be smoother running all around... I figure something was binding, but I can't tell you what.
    May 2004
    12
    Quote Originally Posted by Murray MacKenzie
    Thanks a lot! I'll definitely give this a try.
  16. Remove Advertisements
