2000 DeVille door problems
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2000 DeVille door problems in Past Cadillac Vehicle Discussion; My rear passenger door doesn't have power to lock, window, light and the speaker doesn't work. I think the fuse ...
    bphill is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2007
    4
    My rear passenger door doesn't have power to lock, window, light and the speaker doesn't work. I think the fuse is good, the guy at Cadillac told me the back doors share a fuse. I pulled it and the other door went dead also. So, if he was correct then the fuse must be good. The wires that feed into the door are messed up on that side, could this be the problem? I have included a picture (I hope) of the doors side by side for comparison.
    If this is the problem, what is involved in the repair?
    jasper60103 is online now Cadillac Owners Fanatic
    Automobile(s): '04 Base Deville, Light Platinum
    Apr 2007
    53
    162
    Re: 2000 DeVille door problems
    yeah, it obvious that sleeve is being pinch in the door jamb.
    I would start there. Likely some broken wiring inside.
    You may be able to splice in a new peice and work that
    kink out the sleeve.
    turbojimmy's Avatar
    turbojimmy is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
    Apr 2004
    New Jersey
    3,963
    Yes, that wiring harness is all kinds of messed up. That plastic tube should retract into the door when it closes, not get all pinched up. It's damaged the door, too, apparently.
    You'll probably need to replace that sleeve though I'm not sure how you'd get the wiring out of it. Best case is you'll have to repair the wiring in that sleeve and do your best to straighten it out so the door closes without pinching it.
    I had a ground wire break in that same door on my car for the same reason (though mine wasn't kinked that bad). I took the door panel off to get some slack on the wires and also pried that rubber boot away from the body of the car to get some room to work. I soldered the wire back together and taped in a splint where the kink was to keep that tube from bending.
    HTH,
    Jim
    dantemoravil's Avatar
    dantemoravil is offline Cadillac Owners Fanatic
    Automobile(s): Devilles: 04 Base,01 base,01 DHS,92 (parents)
    Nov 2011
    Cincinnati, Ohio
    51
    211
    its my turn for this issue. rear passenger door.
    having a terrible time trying to find part number to order new one. I pulled one from junkyard but 2 pins aren't included in the connector to the pillar/rest of car. my deville is base model 2001
    I think it is part 20 on this picture.
    this is where I got that picture above. http://www.gmpartseast.com/Page_Prod...=66O&Year=2001
    I cant seem to figure out a correct part number to search other places for this. can someone assist me?
    Thank you in advance.
    Mike
  7. Remove Advertisements
