Cadillac DeVille 1985 to 2005 including: 1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille, 1985-1992 Fleetwood and 1993 Sixty Special. | Cadillac Forums: Does something "engage" after taking off and getting up to 5-10 mph or so?
01-30-08, 03:49 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Does something "engage" after taking off and getting up to 5-10 mph or so? I've got a 1992 Deville with 74K. Just trying to diagnose something that very well may be normal....it's been doing for as long as I can remember. I get in the car, start it, and take off normally and within a few seconds, it sounds like something "engages"...almost like something that turns with the engine "kicks in". I'm having difficulty finding words to describe it, but being an anal kind of guy...I've always been curious about what it was and if it was normal. It's not horribly loud or anything and someone riding in the car with me may not even notice it, but now that I know it does it every time, I hear it every time.
Thanks in advance! |
01-30-08, 03:53 PM
|  | Cadillac Owners Member Cadillac(s): 2000 Cadillac Deville DHS | | Join Date: Jan 2008 Location: Missouri | | | Re: Does something "engage" after taking off and getting up to 5-10 mph or so? what your describing might be traction control or it simply shifting gears. also might be a bad motor mount. |
01-30-08, 04:09 PM
|  | Cadillac Owners Fanatic Cadillac(s): 91 sedan deville | | Join Date: Jan 2007 Location: san antonio, tx Age: 26 | | | Re: Does something "engage" after taking off and getting up to 5-10 mph or so? It might be the air pump coming on for the rear air struts. |
01-30-08, 05:12 PM
|  | Cadillac Owners Member Cadillac(s): 2000 Cadillac Deville DHS | | Join Date: Jan 2008 Location: Missouri | | | Re: Does something "engage" after taking off and getting up to 5-10 mph or so? thats true my 90 deville usally raised back up about 30 after i got in the car. but you could hear the suspension rise. |
01-30-08, 05:33 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Does something "engage" after taking off and getting up to 5-10 mph or so? Start the car, after an overnight period, and just sit. After 6 seconds does something behind your right ear go "Hmmmmmmm" for 3 seconds and quit ?
It's the rear level control compressor proving out.
Open the trunk, start the car. You and a friend sit on the trunk lip. Does the compressor start and level the car ? OK, now y'all hop off and quickly listen under the right rear fenderwell. Air bleeding down ? Good to go. |
01-30-08, 05:37 PM
|  | Cadillac Owners Fanatic Cadillac(s): 1997 Deville Concours | | | | | Re: Does something "engage" after taking off and getting up to 5-10 mph or so? Does the noise continue until you turn the motor off?
DAVE
'97 Concours |
01-31-08, 12:57 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Does something "engage" after taking off and getting up to 5-10 mph or so? Thanks for the prompt replies guys...
My noise only lasts for about 1 second...always exactly the same sound and same duration. Sounds to me like it's coming from somewhere up front but not sure. I haven't really tried narrowing it down and troubleshooting exactly when it happens, such as whether it's only after taking off from a cold start vs. every time i take off, even when it's warm, etc.
I don't believe it's the sound of shifting gears, but guess traction control could be a possibility. I wasn't aware of the 1992 Deville having traction control? |
01-31-08, 01:51 PM
| | Cadillac Owners Member Cadillac(s): 1991 Cadillac Fleetwood | | | | | Re: Does something "engage" after taking off and getting up to 5-10 mph or so? Its the ABS pump doing its self check. Happens every time you start the car around 5-10 mph. That just lets you know its working!  |
01-31-08, 04:17 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Does something "engage" after taking off and getting up to 5-10 mph or so? I'll buy that, now that we know what end of the car the noise is coming from. |
01-31-08, 09:01 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Does something "engage" after taking off and getting up to 5-10 mph or so? What a relief !! It's a relief knowing that the sound is normal
Thanks again for all the helpful input.
Robert | | Cadillac Discussion Tools | | |
Censor is ON | | | |
