Signal light problems
Results 1 to 2 of 2
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Signal light problems in Past Cadillac Vehicle Discussion; '89 Sedan DeVille I keep blowing signal light fuses, I've been through 3. I have a small pebble sized opening ...
    flawson's Avatar
    flawson is offline Cadillac Owners Member
    Automobile(s): 1996 STS
    Mar 2004
    Raleigh NC
    12
    '89 Sedan DeVille I keep blowing signal light fuses, I've been through 3. I have a small pebble sized opening on my drivers headlight. There's condesation inside, is this the possible culprit causing my fuses to blow? Can this be changed easily?
    Imprl59 is offline Cadillac Owners Fanatic
    Jan 2004
    300
    Re: Signal light problems
    The hole is probably not the problem. Normally headlights are fused separatley from the signal lights. I would suspect that you have a damaged wire somewhere in the circuit.
    Steve B.
