Blower motor relay
Results 1 to 14 of 14
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Blower motor relay in Past Cadillac Vehicle Discussion; My blower motor won't shut off when I turn off the car. I pulled the super fuse temporarily. I'm guessing ...
    devil is offline Cadillac Owners Member
    Apr 2004
    16
    Blower motor relay
    My blower motor won't shut off when I turn off the car. I pulled the super fuse temporarily. I'm guessing that theres a NO relay somewhere thats faulty. But it doesn't tell me anywhere that I can see which one it is. Anyone know. Its a 92 Sedan deville> thanks
    Apr 2004
    16
    Re: Blower motor relay
    Someone told me it might be the blower control module. What/Where is this located. Thanks
    Night Wolf's Avatar
    Night Wolf is offline Cadillac Owners 10000+ Posts
    Automobile(s): Unicycle
    Mar 2003
    Where I park it
    11,009
    OMG this is the EXACT same problem as I have been having for the last 3 days.... I washed my car, got home, shut it off, adn the blower motor stays on.... I pulled the fuse, but have no climate controls right now....
    ....something that got me wondering was, why when the ECC is *OFF* air owuld come out of the defrost vents and the floor duct, then it got me thinking, even when it is off, there is always some airflow going throw, so the ECC probably just makes air come out of those vents, and normally the blower wouldn't be on....
    ....we have looked EVERYWHERE and check the whole factory service manual for a blower relay.... there is none, what we think it is now is the blower control module.... it is the only thing that can be wrong....
    my car is a 1993 Coupe DeVille..... I find it strange that 2 people are having the same problem on a similar car at the same time.... please e-mail me at InoventionsEast@optonline.net, as I would like to keep in touch about this, and maybe we can help each other out.
    Apr 2004
    16
    That;s what I've been told but I don't know where the control module is. I looked in Chiltons but its not shown.
    Kinda lousy cause its starting to get hot out.
    RBraczyk's Avatar
    RBraczyk is offline Cadillac Owners Connoisseur
    Jan 2004
    Amherst, NH
    29
    4,178
    Check a Haynes manual, i know their as good as asspaper but they may help in this situation.
    Apr 2004
    16
    Quote Originally Posted by RBraczyk
    Found a copy for RWD models. No reference to control module
    Apr 2004
    16
    Quote Originally Posted by Night Wolf
    As soon as I remove and replace mine I;ll let you know how it works out.
    RBraczyk's Avatar
    Jan 2004
    Amherst, NH
    29
    4,178
    Did you guys consider changing the fuse? Even though it looks fine it might not be working properly.
    Apr 2004
    16
    I tried swapping that first thing. Its one of those big :super fuses: still wouldn't shut off.
    Winn is offline Cadillac Owners Member
    Apr 2004
    10
    Dear All,
    I had thissame problem about a month ago and someone here told me that it was blower moter module. Since I am in Thailand, I am waitig for this part to come from the US. If you still cannot find the module here is where it is. Look in the engine compartment at the blower which should be near the center of the car. Then you will see big plateic cover above that. You have to unscrew two nuts to take the cover off. Then trace the wire from the blower you will get to the modeule. It's a like a small computer box. Hope this help. I have 1 990 Deville.
    Apr 2004
    16
    OK, it was the blower control module.
    If it ever happems to you the BCM is located under the relay panel in the engine compartment up against the firewall.
    You need to remove a few nuts and screws and the entire relay box will lift out of the way.
    The blowe control module is right below that. Its bolted into a black plastic box thing. A new one is about $140.00.
    Junkyard $5.00
    jfolker is offline Cadillac Owners Member
    Mar 2004
    34
    Uhm, BCM = BODY control module.... What exactly was replaced because i'm having a problem with the blower coming on and off random times and the fuel mileage, radio, climated control flashing a buch of times.... I hear a relay click but nothing. So I was thinking about replacing the BCM.
    jf
    Apr 2004
    16
    SmileRe: Blower motor relay
    Sorry about calling it a bcm
    I replaced the Blower Control Module.
    Sounds like you have some kind of a loose ground or something though
  16. #14
    HaYnBenz is offline Cadillac Owners Member
    Nov 2003
    Waikele, Hawaii
    53
    7
    I have 1993 deVille and took out the relay/fuse panel next to the firewall. I removed a little black box, but it is attached to a piece of aluminum with fins. Looks something like an amplifier with fins to dissipate heat. Is this the module?
    I think it is according to another post. If I get it fixed, I will email pics to anyone who cares to have them.
    It is DELCO part number 16173860.
    Thanks!
  17. Remove Advertisements
