99 keyless entry option or standard
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 99 keyless entry option or standard in Past Cadillac Vehicle Discussion; I got a used 99 and didnt get any remotes with it. Was this just an option or sandard? If ...
    merfsiu is offline Cadillac Owners Member
    Apr 2004
    22
    Question99 keyless entry option or standard
    I got a used 99 and didnt get any remotes with it. Was this just an option or sandard? If it was standard i assume i can get remotes off of ebay to work. Can someone point me to the info on how to program them?
    El Dobro's Avatar
    El Dobro is offline Cadillac Owners Connoisseur
    Sep 2003
    1,471
    Re: 99 keyless entry option or standard
    It should be standard and you need two transmitters, one marked #1 and one marked #2.
    jvoortman is offline Cadillac Owners Member
    Feb 2004
    11
    You should check with your local dealership, they can tell you what numbers need to be on the back of the key fob, or else it won't work for your car. I received one from an ebay auction before knowing this. The number on this one read;GM16186066, CANADA:218101375 Model/FCC ID:AB01602T. I have since found the correct numbers, and bought that one, and it is on it's was to me. Remember, you will still need to take it to a dealership to get it programmed (cost is around $50.00) The RKE (remote keyless entry) is what I typed in at ebay to find a zillion listings. Good luck to you.
    Apr 2004
    22
    thanks
    Robert Brandtjen is offline Cadillac Owners Member
    Apr 2004
    49
    Here are the numbers you need for your 1999-
    #1 key- Gm/UTA 25656444
    FCC ID KOBUT1BT
    CANADA 1983 101 393
    #2 key- Gm/UTA 25656445
    FCC ID KOBUT1BT
    CANADA 1983 101 393
    You can find them on Ebay far cheaper then the dealer's $75.00 or so. The dealer should be happy to program for you.
  8. Remove Advertisements
