Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: theft system problem car may not restart
Old 10-09-07, 06:19 AM
lukky4u's Avatar
View lukky4u's Photo Album
Casino Cash: $605
I have searched this site to see if i could find more info on this topic but did not find much. heres my story. 98 deville - one morning out of the blue...get messages saying starting disabled remove key. after about 2 hrs of searching this sight and going out and trying to start, i was able to get the car started.
but
now the message comes up theft system problem, car may not restart.
from what i was able to search on this site it seems that there are 2 small wires by the ignition in the steering wheel column that may have become brittle and need to be replaced. ....does this make sense ? and if this is the case ....is it a hard repair?
  #2 (permalink)
Old 10-09-07, 01:28 PM
View Ranger's Photo Album
Casino Cash: $23801
Re: theft system problem car may not restart
It is possible. Have you tried a spare key? Have you pulled the DTC's?
  #3 (permalink)
Old 10-09-07, 02:23 PM
Cadillac(s): 97 Deville
View pnj2108's Photo Album
Casino Cash: $919
I agree with Ranger i would try a spare key because i had something like that happen to me and the first thing the guy at the dealer did was check the key because he said the metal contacts on the key chip can be wore out. I would try a spare key first before going and trying to replace the wires.
  #4 (permalink)
Old 10-10-07, 12:38 AM
lukky4u's Avatar
Casino Cash: $605
sounds like a good suggestion...i'll do both
  #5 (permalink)
Old 10-15-07, 03:14 PM
Cadillac(s): 1998 Cadillac Deville
View Ramlo1941's Photo Album
Casino Cash: $250
I hate be the bearer of bad news but the same thing happened to me, the difference being that I could never start mine, new key or not. I took it to the Caddy Dealer here in Cleve, Oh and after $980.00 my Deville started. They replaced the Cluster they told me. Shortly after that, they replaced the same part under the warranty and yet again a third time, go figure. While there the started went while the auto was standing still, I got an idea that this may have been the original problem. One more thing that went wrong while the car was idle in place, the Wiper Motor and now they tell me I need an Alternator. I am not going there anymore and I wish I could report it to someone, I believe they just took my money or at least some of it. Good Luck to you.
  #6 (permalink)
Old 10-15-07, 08:57 PM
cadillac_pimpz's Avatar
Cadillac(s): Custom 2005 Cadillac Deville, Pimp Edition
View cadillac_pimpz's Photo Album
Casino Cash: $1503
but
this happened to me soon after buying my 2000 deville. seems to be a problem with the 2000, but I tried changing the battery and eventually found out it was the security system and the dealership fixed it for like $700-900. It wasn't very fun. hahaha I think it is a computer problem, not a physical problem.
  #7 (permalink)
Old 10-16-07, 02:14 AM
lukky4u's Avatar
Casino Cash: $605
I tried the other key and had no codes...not sure what to do at this point...it still starts up and runs no problems but still get the same message. is it possible that it really might not restart?
  #8 (permalink)
Old 12-13-07, 11:07 PM
Cadillac(s): 1999 Cadillac El Dorado
View klane's Photo Album
Casino Cash: $310
This is the same warning message I have presently on my car but I have had no problems starting my 99' El Dorado so far. My dealer serviceman said it is the chip in the ignition cylinder that has failed and needs to be replaced. The part was quoted as $100 plus $100 to program 2 new keys. Total cost quoted with labor was around 650 bucks. I told him no thanks. Another mechanic I use from time to time said that he would do the job for $300. I was hoping it was a job I could attempt but after reading the other posts I guess I'll let him do the job.
  #9 (permalink)
Old 12-14-07, 06:27 AM
N* Headgasket Survivor
Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold)
View chubbyranger's Photo Album
Casino Cash: $700
If you have the chips in the keys search on bypassing VATS. If that is your problem the solution can be a $2 resistor and some uncomfortable time upside down wiring under the dash.
  #10 (permalink)
Old 12-18-07, 04:36 PM
Cadillac(s): Cadillac
View 479bill's Photo Album
Casino Cash: $275
Ok ..so you install a resistor...same problem...disconnect batt and reconnect and car tries to start for a second then same thing.
  #11 (permalink)
Old 12-18-07, 08:56 PM
SlxAlxx's Avatar
View SlxAlxx's Photo Album
Casino Cash: $3309
I had the same exact issue. It's the Theft Deterrent Module in the bottom of the steering column. The keys have to be reprogrammed along with the module replacement.
Tags: , , , , ,
car, problem, restart, system, theft
