94 Deville idle sound
Results 1 to 10 of 10
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 94 Deville idle sound in Past Cadillac Vehicle Discussion; When I'm idling after driving on the freeway or after driving for a while, the engine makes a sort of ...
    Big Drate is offline Cadillac Owners Member
    Apr 2004
    Phoenix
    32
    12
    Lightbulb94 Deville idle sound
    When I'm idling after driving on the freeway or after driving for a while, the engine makes a sort of electrical sound like like wires touching-its hard to explain. One of my friends said it was a timing belt, but I'm not sure he knows what the hell hes talkin about. I dont want to take it to the dealership if I can do the work myself. HELP
    elwesso's Avatar
    elwesso is offline Cadillac Owners Master
    Automobile(s): 2005 CTS-V, 1994 Infiniti Q45
    Jan 2003
    Indiana
    7,668
    Re: 94 Deville idle sound
    So basically its making a ticking noise, that correlates with engine speed..
    So at idle its tick tick tick tick and a little higher its ticktickticktickticktick
    You get the idea
    Is this correct?
    Apr 2004
    Phoenix
    32
    12
    no its just at idle it makes more of a buzzing noise
    sonnycrack is offline Cadillac Owners Member
    Feb 2004
    46
    I have that same sound.. I have a 94 as well.. Hopefully someone can help.. I never hear it except when I'm at a drivethrough window, obviosly because the sound is bouncing back.. ANNY HELP?
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    29
    2,795
    Well your engine doesn't have a timing belt, so there goes that theroy...
    Stoneage_Caddy's Avatar
    Stoneage_Caddy is offline Cadillac Owners 10000+ Posts
    Automobile(s): 01 frontier , 89 Shelby CSX vnt
    May 2003
    Undisclosed location in FL
    14,607
    "tick tick tick" probably a lifter , looks like a common thing on the 4.9 . even seen (heard) it on northstars , should get a tick every half a second
    electircal buzz type deal .....hmm ...does it sound like a electric motor ? or like a wire sparking ? or is it the afforemtnioned tick ?
    up2ng's Avatar
    up2ng is offline Cadillac Owners Member
    Dec 2003
    New York
    87
    Check all of the Ignition wire and make sure they are not arcing.
    Wait until it's dark and then open the hood, start the motor and see if you see any flashes near the wires.
    Apr 2004
    Phoenix
    32
    12
    Im always hearin it at the drivethru as well, and it definetly sounds like wires sparking
    Robert Brandtjen is offline Cadillac Owners Member
    Apr 2004
    49
    Easiest way to find out if it's a lifter is to go to the drugstore and buy a cheap stethoscope and remove the flat piece and insert a pushrod or something similar, then touch it to the engine above the lifters, moving it in the direction of the sound getting louder.
    If it is a lifter, my advice would be to pull the head and send it in to a shop- one that has a good rep with race car drivers (mud tracks) and have him do the valves and head, meanwhile, you can replace all of your lifters and possibly push rods. If one goes, another will as well soon enough. If your going to go through the trouble of replacing one lifter, just do it right and deal with the whole area. Owning many many vehicles- from dump trucks to back-hoes to high performance cars has taught me one thing- everything is fixable and if your going to do it, do it right the first time through- in the long run, it's the best way, though maybe not the easiest/cheapest at the moment.
    When done, you will have a nicely freshened motor.
    I have read that this isn't worth doing on Northstars- I'm not sure why that would be, though. I had it done on a 1987 all aluminum Porsche and it fairly screamed afterward- also had the factory US chip replaced with a German chip- car screamed. "Kelly's" in West St. Paul, Minnesota did the Porsche heads for me.
    Apr 2004
    49
    P.S.- Sometimes pinholes or loose boldts in the exhaust manifold/headers will make the same sound.
  13. Remove Advertisements
