Cadillac DeVille 1985 to 2005 including: 1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille, 1985-1992 Fleetwood and 1993 Sixty Special. | Cadillac Forums: 1991 Cadi Fleetwood ISC Motor Questions
09-26-07, 11:43 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | 1991 Cadi Fleetwood ISC Motor Questions I have a 91 Fleetwood, i was wondering, when my vehicle is shut down, even for a long period of time, that damn ISC motor continues to ratchet, not loud at all, in fact i have to put my ear up to it to hear it, is it supposed to do that, also i have a problem where she starts but then shuts down after a sec, but starts again on the second try, thanks for any suggestions |
09-26-07, 11:56 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: 1991 Cadi Fleetwood ISC Motor Questions No, it is not supposed to do that. It is failing and that is why it dies. |
09-27-07, 12:24 AM
| | Cadillac Owners Fanatic Cadillac(s): 1988 Coupe Deville, 1991 Coupe Deville, 1989, 1994 Eldorado | | Join Date: Oct 2005 Location: NY Age: 41 | | | Re: 1991 Cadi Fleetwood ISC Motor Questions does the isc motor do the same thing after shutting the engine down for a 88-89 4.5? |
09-27-07, 12:39 AM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: 1991 Cadi Fleetwood ISC Motor Questions Not sure, but I think so. |
11-23-08, 04:14 PM
| | Cadillac Owners Member Cadillac(s): Cadillac Fleetwood 1991 Deville 1991 | | Join Date: Nov 2008 Age: 59 | | | Re: 1991 Cadi Fleetwood ISC Motor Questions I have the same problem when starting und shutting down the ignition. What can I do? |
11-23-08, 04:59 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: 1991 Cadi Fleetwood ISC Motor Questions Have someone start the car while you watch the ISC plunger. If it retracts and stalls the engine, replace it. |
11-23-08, 06:03 PM
| | Cadillac Owners Member Cadillac(s): Cadillac Fleetwood 1991 Deville 1991 | | Join Date: Nov 2008 Age: 59 | | | Re: 1991 Cadi Fleetwood ISC Motor Questions The plunger does not retract, it moves sometimes in and out, and there is no gap between the plunger and the throttle positioner |
11-23-08, 09:26 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: 1991 Cadi Fleetwood ISC Motor Questions Might want to get a fuel pressure gauge on it and make sure you have good fuel pressure. Yours might be a failing fuel pump. |
11-24-08, 02:53 AM
| | N* Headgasket Survivor Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold) | | Join Date: Apr 2007 Location: The Ocean State Age: 46 | | | Re: 1991 Cadi Fleetwood ISC Motor Questions Quote:
Originally Posted by haemka The plunger does not retract, it moves sometimes in and out, and there is no gap between the plunger and the throttle positioner | The ISC on my 1990 used to twitch after shutdown, but only for a few seconds. It never really affected anything and the car ran fine so I just lived with it. Is yours causing a problem? |
11-24-08, 04:06 AM
| | Cadillac Owners Member Cadillac(s): Cadillac Fleetwood 1991 Deville 1991 | | Join Date: Nov 2008 Age: 59 | | | Re: 1991 Cadi Fleetwood ISC Motor Questions Yes, the problem is, when I press the gaspedal to start the car, the first moment happens nothing but than it accelerates heavy. Cruising is no problem and the fuel consumption is also ok. |
11-24-08, 11:35 AM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: 1991 Cadi Fleetwood ISC Motor Questions No need to press the pedal when starting on a fuel injected engine. That's an old outdated carburetor method. Try starting without touching it. |
11-24-08, 04:06 PM
| | Cadillac Owners Member Cadillac(s): Cadillac Fleetwood 1991 Deville 1991 | | Join Date: Nov 2008 Age: 59 | | | Re: 1991 Cadi Fleetwood ISC Motor Questions Sorry, It is a missunderstanding. I don't press the pedal when I start the engine.
I mean when I driveaway the car. For the first moment there is no acceleration, so that I have to press the gaspedal very very slow, to avoid that the car makes a jump. By the way, the ECM Trouble Code is 49 (Air injection Reaction system fault. |
11-24-08, 05:30 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: 1991 Cadi Fleetwood ISC Motor Questions That sounds like it might be a bad TPS. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
