Got My 1992-1993 Deville Service Manual!! - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Got My 1992-1993 Deville Service Manual!! in Past Cadillac Vehicle Discussion; Is it a huge file? If not maybe you could email me it sometime flexor68@go.com Thanks...
  1. #16
    devil is offline Cadillac Owners Member
    Apr 2004
    16
    Re: Got My 1992-1993 Deville Service Manual!!
    Is it a huge file?
    Thanks
  2. #17
    MFkimo is offline Cadillac Owners Member
    20
    '93 Sedan Deville: 1st rear driver side window won't go down trying to remove door panel to get inside and take a look at motor
    2nd: antenna stuck up won't go down, motor runs non-stop antenna stuck
    Help Please!!!
  3. #18
    Msilva954's Avatar
    Msilva954 is offline Cadillac Owners Connoisseur
    Automobile(s): 92 Deville
    Aug 2003
    Orlando Florida
    29
    1,725
    I can scan it friday....im out of town now visiting relatives....but your second problems sounds likes the gear went bad in the antenna motor.....common problem with power antenna cars.....actually right now were having that problem with my grandfathers Q45. Its simplist to replace the motor.
  5. #19
    20
    Sounds good, thanks a lot!
  6. #20
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,431
    Taking the back door panel off is the same as the taking the front ones off. Read the replies about that in this post and you'll get your answer.
  7. #21
    20
    thanks
  8. #22
    20
    You Wouldn't Happen To Have Instructions On How To Remove The Parking Light Enclosures For Cleaning? Either My Hands Are To Big To Get Underneath The Bumper Or I Just Don't Know What I'm Doing, Help!
  9. #23
    20
    N
  10. #24
    klt
    klt is offline Cadillac Owners Member
    Jul 2004
    42
    Each of the front parking lights have two electrical connectors, one screw, and one clip holding them in place. The holes for the lamps are not very big so it is still difficuit to clean. The screw are to the outside and the clips on the inside edge of the light assembly. There are holes in the back side of the bumper so you can reach the screw and/or clip. I think the clip is something you depress so it will go back through the hole. I had to replace a lot of the front end on my daughter's '91 DeVille after she had a close encounter. Found all of the parts and practiced as needed at the local U-PULL-IT. Some one told me that if I could figure out how to get the part of of a wreck I could figure out how to put it back on my car. Works for me.
  11. #25
    LCC
    LCC is offline Cadillac Owners Member
    Automobile(s): DEVILLE SEDAN 1993
    Nov 2015
    49
    5
    Hi, I own a DeVille Sedan 1993 and sometimes I can't get out P the shifter. I guess I have to replace the BTSI solenoid. Can you please have a look in your manual and let me know where is it located? Is it inside the transmission pan? or just by the steering colum. Thanks
  12. #26
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,370
    Quote Originally Posted by LCC View Post
    don't hold your breath waiting for a reply -
    this thread has been dead since JULY - 2004 -
  13. #27
    red-oak is offline Cadillac Owners Member
    Automobile(s): 1993 Deville
    Jun 2013
    60
    66
    It is best to have your own manual they are easy to obtain I got mine off flea bay two mounts ago
  14. #28
    LCC
    Nov 2015
    49
    5
    Thank you for letting me know
  15. Remove Advertisements
