"LIGHTS OUT!!!"
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, "LIGHTS OUT!!!" in Past Cadillac Vehicle Discussion; IM HAVINBG A PROBLEM GETTIN AT MY LICENSE PLATE LIGHT BULB CAN ANYYONE HELP. I NEED TO KHOW HOW TO ...
    Cadillac-Junkie's Avatar
    Cadillac-Junkie is offline Cadillac Owners Member
    Mar 2004
    EVERETT MASS
    50
    82
    "LIGHTS OUT!!!"
    IM HAVINBG A PROBLEM GETTIN AT MY LICENSE PLATE LIGHT BULB CAN ANYYONE HELP. I NEED TO KHOW HOW TO GET AT IT. WHO DONE IT? OR ANYONE KNOW HOW TO DO IT?
    THANKS INADVANCE,
    Sal
    Mar 2004
    EVERETT MASS
    50
    82
    Re: "LIGHTS OUT!!!"
    RECAP:Since couldnt get no help i went into this 1 blind and replaced the back license plate bulb. didnt know what i was doing at first and i snapped a couple of plastic pieces to the back up light frame thinking a screwdriver would pop it out but,noooo but nuttin super glue couldnt fix. once i relized you had to pull the whole back up light assembly off i was ok.
    1st>... unscrew license plate screws
    2nd>... unscrew the two little screws on the top part where the license plate lens light is.
    3>...pop of the 5-6 black rivets that surround your electric trunk ull down motor
    4... on the inside of the trunk right on the back side of truck on the right and left side of the pull down trunk motor there are two screws undo them and the whole back assembly pulls off and just replace with replacment bulbs. good luck Sal
    Mar 2004
    EVERETT MASS
    50
    82
    Re: "LIGHTS OUT!!!"
    RECAP:Since couldnt get no help i went into this 1 blind and replaced the back license plate bulb. didnt know what i was doing at first and i snapped a couple of plastic pieces to the back up light frame thinking a screwdriver would pop it out but,noooo nuttin super glue couldnt fix. once i realized you had to pull the whole back up light assembly off i was ok.
    3>...pop off the 4-5 black rivets that surround your electric trunk pull down motor wioth neddle nose pliers
    4... on the inside of the trunk right on the back side of truck on the right and left side of the pull down trunk motor there are two screws undo them and the whole back assembly pulls off.
    5>.. just replace with any color replacment bulbs you want... Good Luck, Sal
