Power Window problems on 1991 Coupe DeVille
Results 1 to 2 of 2
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Power Window problems on 1991 Coupe DeVille in Past Cadillac Vehicle Discussion; I let down the drivers side window and now I can not get it to go up again. The motor ...
    epwolfe is offline Cadillac Owners Member
    Apr 2004
    1
    UnhappyPower Window problems on 1991 Coupe DeVille
    I let down the drivers side window and now I can not get it to go up again. The motor seems to be ok, it just won't raise the window. HELP
    DMG489 is offline Cadillac Owners Member
    Dec 2003
    69
    8
    Re: Power Window problems on 1991 Coupe DeVille
    could be one of two common problems
    1. could be a bad up/down switch
    2. could be a bad winding in the window motor
    and easy check is to take a 12v cordless drill battery and hook up temporay connection wires from the battery to the motor and if it works your problem is with the switch. Sometimes if you reverse your tempory wires it will raise the window for you. If all else fail take it to your local auto glass replacement shop and they should be able to figure out whats wrong and maybe if they have a older mechanic who knows how to work on doors get it in the up position for you. I work in a auto glass shop and that is what we do for our customers
