Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: Bad ABS module in 1990 Fleetwood
Old 06-04-07, 02:28 PM
View only1kairi's Photo Album
Casino Cash: $275
My father has a 1990 FWD Fleetwood. The brakes are really stiff and his mechanic told him it was the ABS unit producing problems. The mechanic then mention the the ABS unit is a rare and hard part to get for these cars. I just want to know if anyone else has ran into this problem and how did they solve it.
Please note the brakes do appear to be working, they are just really tight. Thanks in advance.
  #2 (permalink)
Old 06-04-07, 06:50 PM
N* Headgasket Survivor
Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold)
View chubbyranger's Photo Album
Casino Cash: $2100
Re: Bad ABS module in 1990 Fleetwood
I've never heard of an ABS unit causing stiff brakes - that sounds more like a bad vacuum booster or master cylinder. ABS was an option in 1990 that I don't think was that common. I'd get a 2nd opinion at a good brake shop.
  #3 (permalink)
Old 06-04-07, 07:36 PM
Cadillac(s): '92 Seville
View cadillac_tech's Photo Album
Casino Cash: $910
Does the pedal feel stiff like you have to push REAL hard to stop, or is it stiff at the bottom of travel only? Do the ABS and Red brake warning light come on? Can you go into an ABS stop by slamming the pedal at 20 mph? Or is it actually not ABS equipped? Being a Fleetwood, I'd guess it has it and if the accumulator is bad, the warnings will come on.
  #4 (permalink)
Old 06-05-07, 11:51 AM
Casino Cash: $275
It feels stiff like you have to push REAL hard to stop. And yes the ABS and Brake light comes on. I haven't ever felt the ABS on that thing. I have a 94 STS and the ABS come one every once in awhile in the city if I slam on the brakes. It does have the ABS system in it. Do you think he should get a second opinion?
  #5 (permalink)
Old 06-05-07, 12:41 PM
Casino Cash: $910
It sounds like a bad accumulator. If the lights are out, come on after applying the brake, then go out shortly after releasing the brake, you have a bad accumulator. It is the fist size black ball next to the fluid reservoir. It is serviceable - easy to do.
Pump the pedal 25 times with the key off so no pressure is remaining, unscrew it, and screw on the new one.
  #6 (permalink)
Old 05-26-08, 12:59 AM
Cadillac(s): Cadillac
View Jim Hatt's Photo Album
Casino Cash: $275
cadillac tech,
I have the exact same problem with a 1990 Fleetwood. Hard pedal, ABS lights (Orange & Red) come on when pedal is pushed and go out when released. I found the black ball with the warning label on it that says to pump brake 25 times before removing. My question is... What is the proper name of it. I cannot find ABS Accumulator on any of the online auto parts stores.
Tags: ,
1990, abs, bad, fleetwood, module
