13mpg all the time?
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 13mpg all the time? in Past Cadillac Vehicle Discussion; 4.9L Deville (93, 88k miles). New plugs, filter, oil changed, new front wheel bearings (not dragging), brakes ok, suspension good, ...
    jfolker is offline Cadillac Owners Member
    Mar 2004
    34
    13mpg all the time?
    4.9L Deville (93, 88k miles). New plugs, filter, oil changed, new front wheel bearings (not dragging), brakes ok, suspension good, abs light on (working on it).
    Is 13 mpg average good? I get about 200-250 miles from a tank and i drive like a grandpa...
    I just replaced the map sensor, and the only code i have in memory is low refriderant.
    thanks
    jf
    90devilleguy's Avatar
    90devilleguy is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 STS-V & 1962 Coupe Deville
    Nov 2003
    Framingham,Ma
    548
    Re: 13mpg all the time?
    Quote Originally Posted by jfolker
    thanks
    jf
    try replacing o2 sesnors.
    Paul Nagy is offline Cadillac Owners Member
    Jan 2004
    Clovis, NM, USA
    53
    Does every shop carry those o2 sensors?
    HippieD9 is offline Cadillac Owners Fanatic
    Nov 2003
    Suburb of Chicago
    34
    176
    o2 sensors are a very common part. Any shop should carry them. FYI, my 92 deville avg's 13.5-14.1 city if I'm being nice. 12.5-13.5 if I'm rompin on it. Good luck!
    Peace,
    D.
    Mar 2004
    34
    Man Hippie, you need o2's also it sounds like.
    Car just posted code E13 ( P013 ). (Trying to make that search friendly). I've read on here before that the 92-93 DeVille's have only 1 o2 Sensor?
    The right bank o2 sensor (what the e13 code means) is bad, and I figured that earlier. Is it the one on the front of the motor (these are FWD and transversly mounted) or the back?
    I think it's the front, but wanted a second opinion.
    THanks,
    jf
    Stoneage_Caddy's Avatar
    Stoneage_Caddy is offline Cadillac Owners 10000+ Posts
    Automobile(s): 01 frontier , 89 Shelby CSX vnt
    May 2003
    Undisclosed location in FL
    14,607
    i think its the back one , dont worry its easy to get at from under it
    i think of it this way , i stand at the drivers side imagining the fender is the firewall and look at the distributor whats on my right is the right bank and whats on the left would be left bank
    i replaced boath of mine , and the fuel filter plugs and hte like , on a road trip i got 24.5 , but i ususly avg around 18-19 , i swotched to 89 octinae this week and i think im getting 11 (only went 150 miles on a fuel fuel load where i usuly go 240 miles)
    RBraczyk's Avatar
    RBraczyk is offline Cadillac Owners Connoisseur
    Jan 2004
    Amherst, NH
    29
    4,178
    When she was running i averaged 20 mpg, unless i felt like hauling ass.
    Mar 2004
    34
    Changed the right bank o2 sensor and still getting E13 (P013) code. Do I need to clear the codes? (I thought that GM's save codes for 50 starts)...
    Nov 2003
    Framingham,Ma
    548
    clear the code and it shouldn't come back if it does then something else isn't right.
  12. Remove Advertisements
